Hi Palak,
You need to indent your code inside the while loop. As mentioned a while ago here on the list, if you do this inside CS-Studio you will probably freeze the entire UI. What are you trying to do? Maybe in this case you could use the Archiver and export your PV values later.
Cheers, Hugo
I want that my pv should be read and printed continuously. I have written below python code :
from org.csstudio.opibuilder.scriptUtil import PVUtil import os,sys import subprocess import glob from os import path from datetime import datetime while True: pv=PVUtil.getDouble(pvs[1]) i = datetime.now() sys.stdout=open("test2.txt","wb") print str(i), pv '\\n' sys.stdout.close()
But I an getting error: 2016-09-26 15:49:33 ERROR: Failed to register . SyntaxError: ("mismatched input 'pv' expecting INDENT", ('<script>', 8, 0, 'pv=PVUtil.getDouble(pvs[1])\n')) please help me to solve this
- printing value of pv to new line palak shimpee
Re: Danfysik 8500 or 9100 power supply driver Jeong Han Lee
RE: Cross Compiling EPICS base for Xilinx Zynq, Petalinux- Recipe Mooney, Tim M.
<2016>
Re: printing value of pv to new line Hugo Slepicka
<2016>
ANJ, 27 Sep 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
