1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: libCAS: variable size array
To: [email protected]
Date: Sat, 24 Sep 2016 19:06:24 -0400
On 09/21/2016 09:38 AM, Michael Ritzert wrote:
> I have a (EPICS 3.14) CAS application ...
Could you be more specific about the version?  "3.14" spans a decade+.
The RSRV server has supported array size changes since 3.14.12.
Unfortunately the PCAS server does not handle notification of array size
changes.  The API of the GDD container does not distinguish capacity
from current size.  So far no one has found a good way to extend gdd in
a backwards compatible way.
Perhaps you could elaborate on what you are trying to accomplish?
libCAS: variable size array Michael Ritzert
Prev: Re: Andor SDK3 issue - AT_WaitBuffer fails Pearson, Matthew R.
Next: Re: libCAS: variable size array Michael Ritzert
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: libCAS: variable size array Michael Ritzert
ANJ, 25 Sep 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
