Hi Mark,
thanks for confirming this!
Cheers,
Hinko
On 09/23/2016 02:04 PM, Mark Rivers
wrote:
Hi Hinko,
To answer my own question, I think the NDPluginTimeSeries::doTimeSeriesCallbacks() does what I'm after.
Yes, that is correct. Each NDArray callbacks is done with a different asyn "addr". So the plugin must pass the flag ASYN_MULTIDEVICE in the constructor and downstream plugins must subscribe for callbacks using the appropriate "addr".
This is a search to see what plugins call doCallbacksGenericPointer with a non-zero final argument:
NDPluginCircularBuff.cpp: doCallbacksGenericPointer(preBuffer_->readFromStart(), NDArrayData, 0);
NDPluginCircularBuff.cpp: doCallbacksGenericPointer(preBuffer_->readNext(), NDArrayData, 0);
NDPluginCircularBuff.cpp: doCallbacksGenericPointer(pArrayCpy, NDArrayData, 0);
NDPluginColorConvert.cpp: doCallbacksGenericPointer(this->pArrays[0], NDArrayData, 0);
NDPluginFFT.cpp: doCallbacksGenericPointer(pArrayOut, NDArrayData, 0);
NDPluginFile.cpp: doCallbacksGenericPointer(pArray, NDArrayData, 0);
NDPluginFile.cpp: doCallbacksGenericPointer(pArrayOut, NDArrayData, 0);
NDPluginOverlay.cpp: doCallbacksGenericPointer(this->pArrays[0], NDArrayData, 0);
NDPluginProcess.cpp: doCallbacksGenericPointer( pArrayOut, NDArrayData, 0);
NDPluginROI.cpp: doCallbacksGenericPointer(this->pArrays[0], NDArrayData, 0);
NDPluginROIStat.cpp: doCallbacksGenericPointer(pArrayOut, NDArrayData, 0);
NDPluginStats.cpp: doCallbacksGenericPointer(pArrayOut, NDArrayData, 0);
NDPluginTimeSeries.cpp: doCallbacksGenericPointer(pArrayOut, NDArrayData, numSignals_);
NDPluginTimeSeries.cpp: doCallbacksGenericPointer(pArray, NDArrayData, signal);
NDPluginTransform.cpp: doCallbacksGenericPointer(transformedArray, NDArrayData,0);
NDPosPlugin.cpp: doCallbacksGenericPointer(this->pArrays[0], NDArrayData, 0);
So of the standard plugins in ADCore only NDPluginTimeSeries does this.
From: [email protected] [[email protected]] on behalf of Hinxx [[email protected]]
Sent: Friday, September 23, 2016 6:44 AM
To: [email protected]
Subject: Re: areaDetector plugin with multiple outputs
On 09/23/2016 10:41 AM, Hinxx wrote:
I would like to have a single input array into areaDetector plugin and have the plugin deliver multiple arrays as output. Is this possible? Are there any examples?
I would then like to feed the output arrays into other areaDetector plugins.
Hinko
