1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: CSS Boy Write PVs to file
To: Kay Kasemir <[email protected]>
Date: Thu, 22 Sep 2016 12:57:46 +0000
Hi Kay,
> The PV needs to connect. If you get the value right away, you’ll
> receive a null because the PV has not connected and not received the
> initial value, yet.
Thanks for clarifying. So this makes it a bit more unpredictable than I
thought... Waiting thus might not be reliable :-(
> Overall, performing logic like data acquisition should not be handled
> in the user interface.
There are a couple of use cases that do not require any complex logic.
For example saving a snapshot of a waveform PV into a file. For many use
cases it makes more sense to save this file to a client machine.
Example: Reading/writing firmware via waveform PVs. The FPGA engineer
might not even have access to the IOC's file system...
> Better would be to add a listener to the PV which gets notified as
> values arrive.
Sounds reasonable. Can you point us to an example/documentation?
Martin
Martin Konrad
Control System Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
RE: CSS Boy Write PVs to file Iain Marcuson
Re: CSS Boy Write PVs to file Konrad, Martin
Prev: RE: CSS Boy Write PVs to file Mark Rivers
Next: RE: CSS Boy Write PVs to file Iain Marcuson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: CSS Boy Write PVs to file Iain Marcuson
ANJ, 22 Sep 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
