1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: procServ softIOC server - V2.6.1 released
To: EPICS Tech Talk <[email protected]>
Date: Wed, 21 Sep 2016 14:42:03 -0400
Dear All,
procServ V2.6.1 has been released. [1]
The most prominent improvements will be visible on Windows/Cygwin:
* The console command window that was left open is now properly hidden.
* Killing and restarting now works with child processes that spawn more
  (grand-)children (e.g. Java applications).
Other improvements:
* Buffer overflow vulnerabilities have been fixed.
* Log timestamps now work properly on connections that use no line
  buffering.
* Socket options have been fixed to make sure no two instances of
  procServ run on the same port.
Full change log available at
https://github.com/ralphlange/procServ/releases/tag/V2.6.1
Thanks a lot to Freddie Akeroyd, Mark Rivers and Alireza Panna, who were
contributing code and testing time.
procServ is part of the official distributions of Debian/Ubuntu (as
"procserv") and Fedora/RHEL (as "procServ"). New versions usually take a
few days to get into their respective repositories, but will eventually
be available using the standard package managers.
Enjoy! Pull requests welcome!
~Ralph
[1] procServ is a wrapper application that runs any process (e.g.
a softIOC, a CA Gateway, an archive engine...) in the background,
allowing telnet access to its stdin/stdout.
It supports logging, child restart (manual or automatic on crash/exit),
blocking characters that are considered dangerous to the child, and
much more.
http://sourceforge.net/projects/procserv/
Prev: Re: Archive Appliance Backends Shankar, Murali
Next: CSS Boy Write PVs to file Iain Marcuson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: libCAS: variable size array Michael Ritzert
ANJ, 25 Sep 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
