1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Long string command to device
To: <[email protected]>
Cc: [email protected]
Date: Tue, 20 Sep 2016 12:45:00 +0000
> Thanks for the fast answer.
> Then the problem must be of a different kind (I am rather new to EPICS).
> I have the following database records:
> record(waveform, "$(P):RAW2") {
>    field(DTYP, "stream")
>    field(OUT, "@Huginn.proto setRAW $(PORT) $(ADDR)")
>    field(FTVL, "CHAR")
>    field(DESC, "RAW waveform lakeshore record")
>    field(SCAN, "Passive")
The problem is simply that, quite confusingly, the control field in a waveform record is called INP, even if the device support is treating it as an out record.  Change OUT to INP and it might work
Re: Long string command to device Pete Jemian
Long string command to device Bo Jakobsen
RE: Long string command to device Mark Rivers
Re: Long string command to device Bo Jakobsen
Prev: Re: Long string command to device Bo Jakobsen
Next: Ospreydcs.com bob dalesio
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Long string command to device Pete Jemian
ANJ, 20 Sep 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
