1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Question about "import MySQLdb" module problem in CSS python script
To: lzf neu <[email protected]>
Date: Sun, 18 Sep 2016 15:00:51 +0000
Hi:
CSS BOY scripts are executed in jython, not python.
Most of the default python modules are also available in jython, but when you install python modules with binary dependencies like numpy, MySQL_python, .. those are not available in jython.
In jython you can instead call all the Java modules included in CS-Studio, for example the RDBUtil which allows access to Oracle, Postgres, MySQL.
But you shouldn’t really do that in a BOY script, because it’ll execute on the UI thread. Database operations are too slow, they will cause your complete UI to freeze.
The display tool was meant to display PVs, not to perform database operations.
If you do enjoy writing python code that interacts with MySQL, just do that outside of the display tool, then add a pcaspy CA server to provide the results as PVs, and display those PVs in CSS BOY.
-Kay
On Sep 18, 2016, at 8:56 AM, lzf neu <[email protected]> wrote:
Hi all,
  I want to import MySQLdb module in CSS to operate the mysql database.
  In order to do this, I have looked up the CSS manual and add the MySQLdb module path ("/usr/lib64/python2.7/site-packages/MySQL_python-1.2.5-py2.7-linux-x86_64.egg/") in the PYTHONPATH that obtained from sys.path;
  The content of python script that I wrote only contain two lines:
  from org.csstudio.opibuilder.scriptUtil import PVUtil
  import MySQLdb
  however, when running the python script in CSS, an error occured and print out the following message:
  Traceback (most recent call last):
  File "<script>", line 2, in <module>
  File "/usr/lib64/python2.7/site-packages/MySQL_python-1.2.5-py2.7-linux-x86_64.egg/MySQLdb/__init__.py", line 19, in <module>
  File "/usr/lib64/python2.7/site-packages/MySQL_python-1.2.5-py2.7-linux-x86_64.egg/_mysql.py", line 7, in <module>
  File "/usr/lib64/python2.7/site-packages/MySQL_python-1.2.5-py2.7-linux-x86_64.egg/_mysql.py", line 6, in __bootstrap__
  ImportError: No module named _mysql
  If I import MySQLdb module directly in python terminal window and everything is OK and no error occurred !
  Any help will be appreciated and thanks in advance !
Zhefu
答复: Question about "import MySQLdb" module problem in CSS python script lzf neu
Prev: Re: Question about "import MySQLdb" module problem in CSS python script Matt Newville
Next: 答复: Question about "import MySQLdb" module problem in CSS python script lzf neu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: 答复: Question about "import MySQLdb" module problem in CSS python script lzf neu
ANJ, 18 Sep 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
