1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: link: invalid option -- n.....make[2]: *** [install.windows-x64] Error 2
To: <[email protected]>, <[email protected]>, <[email protected]>
Date: Sat, 17 Sep 2016 22:44:07 +0000
Hi Max,
I’ve managed to reproduce a epicsTempFile.obj error and in this case it was caused by make not being able to locate the Visual Studio compiler. The express version of Visual Studio does not provide a native 64bit compiler, it only provides a 32bit cross compiler, so if “x64” is passed as the argument to    vcvarsall.bat   within the file     base\startup\win32.bat   the build will fail. Were you using “x64” here? If so, then to get things to work you just need to use  “x86_amd64”  instead to generate a 64bit epics build via the cross compiler. One of the possible issues with using the cross compiler is that being a 32bit program it has the usual 32bit program memory limits etc., so if there was a particularly complicated bit of code to compile or optimisation to perform it might run out of resources.  The 3.15.2 release notes mention not working with the express version due to hitting a compiler limit, I’m not sure of the underlying cause there and whether it will still apply in certain circumstances, but the following setup worked for me:
Windows 10 x64
Strawberry perl 5.24.0.1 x64
EPICS base 3.15.4
GNU Make 4.1 (from https://www.aps.anl.gov/epics/download/tools/make-4.1-win64.zip )
Visual Studio Express for Desktop (2015 update 3)
Freddie
From: [email protected] [mailto:[email protected]] On Behalf Of Max Power
Sent: 16 September 2016 20:22
To: Mark S. Engbretson; [email protected]
Subject: Re: link: invalid option -- n.....make[2]: *** [install.windows-x64] Error 2
Thank you Mark,
After trying again and again using mingw, make 4.1 for windows, and the last version of MVC2015 (free version) both windows 8.1 and windows 10, I have to say that I had always the following error: http://www.aps.anl.gov/epics/tech-talk/2015/msg01742.php, about:
make[3]: *** No rule to make target 'epicsTempFile.obj', needed by 'antelope.exe'.  Stop.
make[3]: Leaving directory 'c:/base-3.15.2/src/libCom/O.win32-x86'
../../configure/RULES_ARCHS:61: recipe for target 'install.win32-x86' failed
make[2]: *** [install.win32-x86] Error 2
make[2]: Leaving directory 'c:/base-3.15.2/src/libCom'
I followed all the indications about the recommendations written in this forwarding, including the modification of the bat file (you mention Mark), but as says Mark at this point, I think the problem is the express edition of MVC2015:
For building base 3.15.2 with Visual Studio 2015 you need to look at the Known Problems page here.
http://www.aps.anl.gov/epics/base/R3-15/2-docs/KnownProblems.html
It says that you cannot use the Express Edition, you must use the Community Edition (or presumably the licensed version).  You also must apply a patch to base as documented on that page.
Finally I had to do waht I didn't want to, and is use cygwing... It compiled at first time.
anyway Thank you very much
Max
2016-09-07 23:48 GMT+02:00 Mark S. Engbretson <[email protected]>:
Normally, a reasonable system to get good builds with Microsoft compilers uses any modern version of pearl,
Mingw, or gnuwin32.
You then modify or use the win32.bat file found in base\startup to point to all your tools.
You run *that* and it sets up all the Microsoft paths for all of its stuff.
Base should then build without a hitch.
Enclosed is how I have my build system set up.for a MSVC2015 system. I renamed the gnu link to be something else since the standard batch file does the directories in the wrong order.   You might try doing a
make clean uninstall
and starting fresh.
Or . . . . if you have a full version of mingw, you could build EPICS with that just to see if it will build or not.
Sent: Wednesday, September 07, 2016 3:51 PM
Cc: [email protected]
Dear Mark,
Thank you very much for your support. Yes you are totally right, I put first in the PATH, the path to the Microsoft LINK command, but It didn't work. Anyway, I have tried to do what Enbregtson said, and Another compiling/linking problems have appeared. I am going to try to understand what is the new problem, and in both cases: I fix the problem or not I will write the solution or the problem :D.
Thank you very much to all
Regards
2016-09-07 21:39 GMT+02:00 Mark Rivers <[email protected]>:
I think you are confusing 2 things:
-          Using gnumake from MinGW, but using the Microsoft Visual Studio compiler and linker.  EPICS_HOST_ARCH=windows-x64 uses the Microsoft compiler and linker.
-          Using the mingw (GNU) compiler and linker.  EPICS_HOST_ARCH=windows-x64-mingw uses the GNU compiler and linker.
If you want to use the Microsoft compiler then you need to make sure that the minGW linker does not come first in your PATH, which seems like what is happening.  You can probably change your PATH definition so the Microsoft compiler tools come before the minGW tools.
Sent: Wednesday, September 07, 2016 2:26 PM
To: [email protected]
Subject: link: invalid option -- n.....make[2]: *** [install.windows-x64] Error 2
Dear guys,
I have tried to install EPICS base 3.15.4 in windows 8.1 64 bits using MinGW tools, following instructions in EPICS.org: http://www.aps.anl.gov/epics/base/win32.php and Mark River explanation.
I have used the last version of Visual studio 2015 and all the building tools required.
After "make" command execution, everything looked going on perfect until the point the installation has used the "link" command (see below). It says that "link" command does not understand -n option. I have checked that the link.exe command installed with VC2015 has the possibility of using that argument, but the link command from MinGW GNU tools cannot. Any idea or someone with the same problem?
Thank you very much in advance!, console outputs coming below
link -nologo  -LTCG -incremental:no -opt:ref -release -version:3.15 /MACHINE:X64
              -out:antelope.exe       epicsTempFile.obj closure.obj error.obj la
lr.obj lr0.obj antelope.obj mkpar.obj output.obj reader.obj skeleton.obj symtab.
obj verbose.obj warshall.obj
Try `link --help' for more information.
make[3]: Leaving directory `/c/Users/Max/AppData/Roaming/SPB_Data/epics/base/s
rc/libCom/O.windows-x64'
make[2]: Leaving directory `/c/Users/Max/AppData/Roaming/SPB_Data/epics/base/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/c/Users/Max/AppData/Roaming/SPB_Data/epics/base/s
rc'
make: *** [src.install] Error 2
link version that the make uses:
$ link
link: missing operand
$ link --version
link (GNU coreutils) 5.97
Copyright (C) 2006 Free Software Foundation, Inc.
This is free software.  You may redistribute copies of it under the terms of
the GNU General Public License <http://www.gnu.org/licenses/gpl.html>.
There is NO WARRANTY, to the extent permitted by law.
Written by Michael Stone.
$ link --help
Usage: link FILE1 FILE2
  or:  link OPTION
Call the link function to create a link named FILE2 to an existing FILE1.
      --help     display this help and exit
      --version  output version information and exit
Report bugs to <[email protected]>.
link: invalid option -- n.....make[2]: *** [install.windows-x64] Error 2 Max Power
RE: link: invalid option -- n.....make[2]: *** [install.windows-x64] Error 2 Mark Rivers
Re: link: invalid option -- n.....make[2]: *** [install.windows-x64] Error 2 Max Power
Prev: Re: link: invalid option -- n.....make[2]: *** [install.windows-x64] Error 2 Max Power
Next: Question about "import MySQLdb" module problem in CSS python script lzf neu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Next: VDCT Paramveer Jain
ANJ, 18 Sep 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
