Hello, I am trying to use the DAQmxBase app https://sourceforge.net/p/epics/svn/HEAD/tree/applications/trunk/DAQmxBase/ with the ni usb 6501 digital io daq. Here are the specifics of my set up: KERNEL: centos 7 (x86_64) uname -a Linux dt-imblin115 3.10.75-rt80 #1 SMP PREEMPT RT Tue Sep 13 16:42:52 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux EPICS Configuration: base-3.14.12.5 asyn-4-30 NIDAQmxBase version 15.0.0 [admin@dt-imblin115 Desktop]$ lsdaq -------------------------------- Detecting National Instruments DAQ Devices Found the following DAQ Devices: NI USB-6501: "Dev1" (USB0::0x3923::0x718A::01B27D57::RAW) -------------------------------- I am able to read/write to digital ports using the example C code provide with nidaqmxbase drivers. I don't have nidaqmx drivers compiled. I compiled the DAQmxBase app and tried to run the digout.cmd with the following output: [admin@dt-imblin115 iocDAQmxBase]$ ../../bin/linux-x86_64/DAQmxBase digout.cmd #!../../bin/linux-x86_64/DAQmxBase cd ../../ # Load binaries on architectures that need to do so. # VXWORKS_ONLY, LINUX_ONLY and RTEMS_ONLY are macros that resolve # to a comment symbol on architectures that are not the current # build architecture, so they can be used liberally to do architecture # specific things. Alternatively, you can include an architecture # specific file. #$(VXWORKS_ONLY)ld < bin/$(ARCH)/DAQmxBase.munch #ld < bin/linux-x86_64/DAQmxBase.munch ## Register all support components dbLoadDatabase("dbd/DAQmxBase.dbd") dbLoadDatabase("dbd/DAQmxBaseSupport.dbd") DAQmxBase_registerRecordDeviceDriver(pdbbase) ## Load record instances dbLoadRecords("db/DAQmxBaseDigOut.vdb","DAQMX=XXX") DAQmxBaseConfig("myport1", "Dev1/port2/line0", 0, "BO","N=1 F=0 m=0 M=5") Setting daqMode on myport1 = BO Option = N=1 Option = F=0 Option = m=0 Option = M=5 Created port "myport1" with devices: "Dev1/port2/line0" asynSetTraceMask("myport1", 0,0x11) iocInit() Starting iocInit ############################################################################ ## EPICS R3.14.12.5 $Date: Tue 2015-03-24 09:57:35 -0500$ ## EPICS Base built Sep 13 2016 ############################################################################ 2016/09/15 17:46:26.498 drvDaqMxBase::drvUserCreate, attempting to create cmd: DATA 2016/09/15 17:46:26.498 drvDaqMxBase::drvUserCreate, command created: DATA 2016/09/15 17:46:26.498 drvDaqMxBase::drvUserCreate, attempting to create cmd: DATA 2016/09/15 17:46:26.498 drvDaqMxBase::drvUserCreate, command created: DATA 2016/09/15 17:46:26.498 myport1 asynManager::queueLockPort locking port 2016/09/15 17:46:26.498 dmbRead: command = 0 (DATA), signal = 0 2016/09/15 17:46:26.498 myport1 queueUnlockPort iocRun: All initialization complete asynSetTraceMask("myport1", 0,0x01) [epics@ipl]:~$ dbl XXX:DATA [epics@ipl]:~$ dbpf "XXX:DATA", "0" DBR_USHORT: 0 0x0 [epics@ipl]:~$ 2016/09/15 17:46:44.554 ### DAQmx ERROR (StartTask): VISA Close in DAQmxBase Stop Task 92xx.vi:2540001->DAQmxBase Stop Task.vi:940001->DAQmxBaseStopTask.vi->DAQmxBaseStopTask.vi.ProxyCaller I am not sure what this error means. Any help is appreciated. Thank you Best, Ali
ANJ, 18 Sep 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
