1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: link: invalid option -- n.....make[2]: *** [install.windows-x64] Error 2
To: EPICS Tech-Talk <[email protected]>
Cc: Max Power <[email protected]>
Date: Thu, 8 Sep 2016 09:18:06 +0200
On 07/09/2016 22:50, Max Power wrote:
Thank you very much for your support. Yes you are totally right, I put first in the PATH, the path to the Microsoft LINK command, but It didn't work. Anyway, I have tried to do what Enbregtson said, and Another compiling/linking problems have appeared. I am going to try to understand what is the new problem, and in both cases: I fix the problem or not I will write the solution or the problem :D.
Usually, it is sufficient to leave the Visual Studio environment settings as they have been set by the vcvarsall.bat script, and just call the top level make from MinGW using its full path (e.g. "C:\MinGW\bin\mingw32-make distclean all").
Cheers,
~Ralph
link: invalid option -- n.....make[2]: *** [install.windows-x64] Error 2 Max Power
RE: link: invalid option -- n.....make[2]: *** [install.windows-x64] Error 2 Mark Rivers
Re: link: invalid option -- n.....make[2]: *** [install.windows-x64] Error 2 Max Power
Prev: Re: link: invalid option -- n.....make[2]: *** [install.windows-x64] Error 2 Max Power
Next: VDCT Paramveer Jain
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Next: Re: link: invalid option -- n.....make[2]: *** [install.windows-x64] Error 2 Max Power
ANJ, 16 Sep 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
