1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Autosave ignores PVs starting with some characters
To: <[email protected]>
Date: Wed, 7 Sep 2016 15:15:38 -0500
On 09/07/2016 03:02 PM, Mooney, Tim M. wrote:
> Turns out EPICS won't load a record whose name starts with '.'
The IOC does reject attempts to create a record whose name has any of
the characters space, double-quote, single-quote, dot or dollar sign in
it anywhere, not just at the beginning of the name. That is the only
enforced naming limitation at the moment.
> caget doesn't work with all PVs whose names start with '-'
Oh yes it does, it follows the Unix standard for command-line arguments
which is that arguments beginning with a hyphen can be given after a
double-hyphen, so:
> tux% caget -- -my-pv
> Channel connect timed out: '-my-pv' not found.
Record names starting with '-' are definitely legal.
- Andrew
Re: Autosave ignores PVs starting with some characters J. Lewis Muir
Autosave ignores PVs starting with some characters Konrad, Martin
RE: Autosave ignores PVs starting with some characters Mooney, Tim M.
Prev: Re: github hides accounts Kevin Peterson
Next: Re: link: invalid option -- n.....make[2]: *** [install.windows-x64] Error 2 Max Power
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Autosave ignores PVs starting with some characters Mooney, Tim M.
Next: Re: Autosave ignores PVs starting with some characters J. Lewis Muir
ANJ, 08 Sep 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
