1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Question about return ping value by using pcaspy in camonitor
To: lzf neu <[email protected]>
Cc: Epics <[email protected]>
Date: Tue, 6 Sep 2016 16:07:00 +0000
Here is the running demo adapted from your post. It runs the ping command every 5 seconds.
$ caget TEST:PING
TEST:PING                      Ok
#!/usr/bin/env python
import os
import threading
import time
from pcaspy import Driver, SimpleServer
prefix = 'TEST:'
pvdb = {
    'PING' : {
    	'type': 'enum',
        'enums': ['Unreachable', 'Ok']
class myDriver(Driver):
    def __init__(self):
        super(myDriver, self).__init__()
        tid = threading.Thread(target=self.determine)
        tid.setDaemon(True)
        tid.start()
    def determine(self):
        while True:
            a=os.system("ping -c 1 -w 1 127.0.0.1")
            if (a==0):
                self.setParam('PING', True)
            else:
                self.setParam('PING', False)
            time.sleep(5)
if __name__ == '__main__':
    server = SimpleServer()
    server.createPV(prefix, pvdb)
    driver = myDriver()
    # process CA transactions
    while True:
        server.process(0.1)
> On 06 Sep 2016, at 10:37, lzf neu <[email protected]> wrote:
> Hi all,
> i want to display the TEST:PING value in camonitor, which is the return value by ping 127.0.0.1.
> i know pcaspy can implement this, but i am newer in it.
> below is the pcaspy program i wrote and there is an error.
> Could you give me some advice and thanks in advance.
> import os
> prefix = 'TEST:'
> pvdb = {
>     'PING' : {
>          a,
>     def __init__(self):
>     def determine():
>         if (a==0):
>             print "communication established !"
>     driver = myDriver()
>     while True:
>         server.process(0.1)
Question about return ping value by using pcaspy in camonitor lzf neu
Prev: RE: ProcServ suggestion - add Date/Time to startup lines Mark Rivers
Next: Re: Support for CAEN SY4527 Jiro Fujita
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Question about return ping value by using pcaspy in camonitor lzf neu
Next: Question about display history data in the form of data reports table in CSS boy opi ? lzf neu
ANJ, 14 Sep 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
