1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: ether_ip linking issue in epics base-3.15
Date: Wed, 31 Aug 2016 22:40:38 +0000
Hi Everyone,
I have a link issue for the ether_ip module.
It has been built well in base-3.14, but I could not build it in base-3.15.
I found that the Makefile in testether_ipApp/src describe softDevIoc and testDevIoc individually.
These are re-organized into different library files in base-3.15.
We don't need to put the individual libraries in the Makefile.
We can just use "eipIoc_LIBS += $(EPICS_BASE_IOC_LIBS)".
The macro contains everything what we need to build an ioc.
So, I would like to make change on the Makefile.
Thank you.
Best regards,
Kukhee
Kukhee Kim
SLAC National Accelerator Laboratory
2575 Sand Hill Rd, MS 64
Menlo Park, CA 94025
Email: [email protected]
Phone: (650)926-4912
Fax:   (650)926-3800
Re: ether_ip linking issue in epics base-3.15 Kasemir, Kay
Prev: edm version 1-12-103 Sinclair, John William
Next: Question about determining network connection by using different LED widget color lzf neu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Next: Re: ether_ip linking issue in epics base-3.15 Kasemir, Kay
ANJ, 01 Sep 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
