Since this problem recently arose again and I failed to document it when
it was originally resolved, I am responding to my own message from two
years ago.
The error messages below are caused by a mismatch between the running
version of VxWorks and the tool chain used to build EPICSbase. For
example, build EPICSbase using a VxWorks 6.9.3 toolchain and then load
it into a VME crate running VxWorks 6.9.4.1 and you will get the error
messages below. The reverse also fails; build EPICSbase under 6.9.4.1
and try running it under VxWorks 6.9.3; same errors messages.
The root cause of this problem is that Intel Wind River Systems made
changes to some data structures (the specifics of which I no longer
recall) that EPICS uses between VxWorks 6.9.3 and 6.9.4.1. Binary
compatibility is apparently not guaranteed between "maintenance"
versions of VxWorks.
Ron
On 8/25/2014 2:41 PM, Ron Sluiter wrote:
We recently tested VxWorks 6.9.4.1 for the 1st time on a teststand and
found some new EPICS error messages that we have not seen before.
osiSockDiscoverBroadcastAddresses(): status: 0x08x, ifconf.ifc_len: -1
osiSockDiscoverBroadcastAddresses(): unable to fetch network
interface configuration
and,
osiLocalAddr(): SIOCGIFCONF ioctl failed because "S_errno_ENXIO"
These error messages appeared only once after iocInit and had no
discernible effect on IOC performance. We are using base-3.14.12.3.
Is anyone else using VxWorks 6.9.4.1?
Are other VxWorks 6.9.4.1 users seeing these error messages?
Ron
Re: 回复: Re: question about pcaspy Wang Xiaoqiang
HOW to start working with EPICS Paramveer Jain
<2016>
Epics for Phoenix Contact ILC 150 ETH New User
<2016>
