1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: question about pcaspy
To: Mark Rivers <[email protected]>, "Kasemir, Kay" <[email protected]>, geyang <[email protected]>
Date: Mon, 29 Aug 2016 15:10:10 +0200
On 29/08/2016 15:03, Mark Rivers wrote:
Doesn’t matter, the easiest way to configure this is still to leave EPICS_CAS_SERVER_PORT undefined
since the clients will find all your IOCs just fine.
The only exception to this is if your clients are on a different subnet from your IOC.  In that case I believe you can use a PV gateway, or set the PCAS server port manually and set EPICS_CA_ADDR_LIST on the client.
Or use the iptables trick documented on the user Wiki:
https://wiki-ext.aps.anl.gov/epics/index.php/How_to_Make_Channel_Access_Reach_Multiple_Soft_IOCs_on_a_Linux_Host
Cheers,
~Ralph
question about pcaspy geyang
Re: question about pcaspy Kasemir, Kay
RE: question about pcaspy Mark Rivers
Prev: RE: question about pcaspy Mark Rivers
Next: Re: 回复: Re: question about pcaspy Wang Xiaoqiang
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Next: A problem while execute MEDM3_1_9 정필규
ANJ, 29 Aug 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
