Thanks for the response. My searches for a solution turned up empty and I was hoping I was just overlooking something.
Randy
Sorry, the original email on this swept by me without recognizing….
No, at the current time, none of the ether/IP drivers, nor any driver I’ve been able to identify is capable of receiving a CIP data stream. I assume you are probably wanting to do a class-0 or class-2 connection
to the PLC, and receive a data stream.
There are a couple of utilities I’ve seen somewhere in the past that would ‘…sort of…’ do that, but nothing you’d want to use for anything other than a little demonstration of capability.
It’s an interesting possibility, and one I’m considering adding as a future driver for EPICS, but to this point, the time required to provide this capability has not become available, so don’t look for the capability
in the near future.
Later-
David Dudley
Controls Engineer III
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7133
Email: dudleyd@frib.msu.edu
Hi Randy,
I didn’t see a reply to this, so I’ll ask a couple of questions.
I don’t really know anything about CIP, but from a quick Google study it appears to be the underlying technology
used in EtherNet/IP, DeviceNet,
CompoNet and ControlNet.
Are you actually using one of those higher-level protocols? What system is generating your CIP messages?
I am new to IOC and PLC programming, so forgive me if this is a newbie question. I search Tech Talk but did not see an answer.
I am working on a project where we will be receiving CIP (Common Industrial Protocol) data. The CIP data stream is not consider critical and is for reference only. Due to reasons beyond my control, the CIP data will need to be processed
by a program (IOC) and not a PLC. I have written an IOC program (C/C++) that receives/sends data to our Allen Bradley PLC using the Ethernet/IP driver. Can the Ethernet/IP driver be configured to receive CIP data, thereby looking and acting like a PLC? Or
is there another IOC layer/driver that could provide this ability? Or is there another solution that I am overlooking?
Many thanks.
