Hello, This is Jung who is a Epics beginner.
I installed epics R3.16.0.1, Extensions
Top (R3.14) and so on.
here is a problem. when I install
sysApps_5_8, I received this error.
make -C
/usr/local/epics/extensions/src/synApps_5_8/support/calc-R3-6-1
install
make[1]: Entering directory
'/usr/local/epics/extensions/src/synApps_5_8/support/calc-R3-6-1'
make -C ./configure install
make[2]: Entering directory
'/usr/local/epics/extensions/src/synApps_5_8/support/calc-R3-6-1/configure'
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
T_A=linux-x86_64 install
make[3]: Entering directory
'/usr/local/epics/extensions/src/synApps_5_8/support/calc-R3-6-1/configure/O.linux-x86_64'
perl -CSD
/usr/local/epics/base/bin/linux-x86_64/convertRelease.pl
checkRelease
make[3]: Leaving directory
make[2]: Leaving directory
make -C ./calcApp install
'/usr/local/epics/extensions/src/synApps_5_8/support/calc-R3-6-1/calcApp'
make -C ./src install
'/usr/local/epics/extensions/src/synApps_5_8/support/calc-R3-6-1/calcApp/src'
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[4]: Entering directory
'/usr/local/epics/extensions/src/synApps_5_8/support/calc-R3-6-1/calcApp/src/O.linux-x86_64'
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE
-D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall
-mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I..
-I../../../include/compiler/gcc -I../../../include/os/Linux
-I../../../include
-I/usr/local/epics/extensions/src/synApps_5_8/support/sscan-2-10-1/include
-I/usr/local/epics/extensions/src/synApps_5_8/support/seq-2-2-1/include
-I/usr/local/epics/base/include/compiler/gcc
-I/usr/local/epics/base/include/os/Linux
-I/usr/local/epics/base/include -c ../sseqRecord.c
../sseqRecord.c: In function ‘putCallbackCB’:
../sseqRecord.c:536:42: error: ‘struct pv_link’ has no member
named ‘precord’
pR = (sseqRecord *)(plink->value.pv_link.precord);
../sseqRecord.c: In function ‘processCallback’:
../sseqRecord.c:604:18: warning: variable ‘did_putCallback’ set
but not used [-Wunused-but-set-variable]
int status, did_putCallback=0;
/usr/local/epics/base/configure/RULES_BUILD:220: recipe for
target 'sseqRecord.o' failed
make[4]: *** [sseqRecord.o] Error 1
make[4]: Leaving directory
/usr/local/epics/base/configure/RULES_ARCHS:61: recipe for
target 'install.linux-x86_64' failed
make[3]: *** [install.linux-x86_64] Error 2
/usr/local/epics/base/configure/RULES_DIRS:88: recipe for target
'src.install' failed
make[2]: *** [src.install] Error 2
'calcApp.install' failed
make[1]: *** [calcApp.install] Error 2
make[1]: Leaving directory
'/usr/local/epics/extensions/src/synApps_5_8/support/calc-R3-6-1.install'
failed
make: ***
[/usr/local/epics/extensions/src/synApps_5_8/support/calc-R3-6-1.install]
Error 2
I guess calc of apps has a problem.
PLEASE help me, How can I do..?
Best regards
Pilkyu Jung
- RE: A Problem while Installing calc in synApps_5_5 Mooney, Tim M.
A Problem while Installing calc in synApps_5_5 정필규
<2016>
<2016>
ANJ, 24 Aug 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
