On 08/19/2016 12:25 AM, Paramveer Jain wrote:
> thanx for your suggestion
You're welcome. Please keep these conversations on tech-talk though,
that way other people can help to answer your questions too.
> I Am trying to install MEDM in linux 6.7
> following is the current problem which I am unable to resolve when i
> m installing it
> usr/include -I/usr/include/X11 ../xgif.c
> /usr/bin/g++ -o medm -L/opt/epics/base-3.14.12.3/lib/linux-x86_64
> -L/opt/epics/extensions/lib/linux-x86_64 -L/usr/lib -L/usr/lib64
> -Wl,-rpath,/opt/epics/base-3.14.12.3/lib/linux-x86_64
> -Wl,-rpath,/opt/epics/extensions/lib/linux-x86_64 -Wl,-rpath,/usr/lib
> -Wl,-rpath,/usr/lib64 -m64 medmCartesianPlot.o
> medmSciPlot.o SciPlot.o medmCA.o actions.o bubbleHelp.o callbacks.o
> browserHelp.o channelPalette.o colorPalette.o dialogs.o display.o
> eventHandlers.o help.o medm.o medmArc.o medmBar.o medmByte.o
> medmChoiceButtons.o medmCommon.o medmComposite.o medmControl.o
> medmDisplay.o medmImage.o medmIndicator.o medmMenu.o medmMessageButton.o
> medmMeter.o medmMonitor.o medmOval.o medmPixmap.o medmPolygon.o
> medmPolyline.o medmRectangle.o medmRelatedDisplay.o medmShellCommand.o
> medmStripChart.o medmText.o medmTextEntry.o medmTextUpdate.o
> medmValuator.o medmWheelSwitch.o medmWidget.o objectPalette.o
> productDescriptionShell.o resourcePalette.o updateMonitors.o
> updateTask.o utils.o xgif.o -lANLwidgets -lPrintUtils -lca -lCom -lXm
> -lXt -lXp -lXmu -lX11 -lXext -lpthread -lreadline -lm -lrt -ldl -lgcc
> /usr/bin/ld: crt1.o: No such file: No such file or directory
> collect2: ld returned 1 exit status
> make[2]: *** [medm] Error 1
> make[2]: Leaving directory `/opt/epics/extensions/src/medm/medm/O.linux-x86_64'
The crt.o file is normally found in the glibc-devel package, but I'm
surprised you managed to get this far without having that package
installed. The only way I can think that could happen is if you have
installed the 32-bit (i686) RPM, but you are building a 64-bit (x86_64)
version of medm. Make sure that the RPMs you have installed are for
x86_64 and not just for i686 — my system has both installed, e.g.
tux% rpm -q glibc-devel
glibc-devel-2.12-1.192.el6.i686
glibc-devel-2.12-1.192.el6.x86_64
- Andrew
- [no subject] Paramveer Jain
- Re: Henrique Almeida
- Re: Michael Westfall
- Re: Andrew Johnson
- RE: Re: Mark Rivers
- Re: Re: Henrique Almeida
Re: MEDM Andrew Johnson
device support for Oxigraf oxygen monitor Sinclair, John William
<2016>
Re: Andrew Johnson
problem in installing MEDM Paramveer Jain
<2016>
