1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Variable SCAN Intervall and Roundoff function
To: <[email protected]>, <[email protected]>
Date: Tue, 16 Aug 2016 23:00:59 +0200
Regarding your first question:
On 16.08.2016 15:32, [email protected] wrote:
> 1.) I have a calcout-record which can increase or decrease a value
> Now I am want to implement a simple variable SCAN-intervall to increase
> every 60 seconds or every hour . But I don't know which is the best way
> to do this and how to implement this in my application. There is a
> solution with the OROC-field but I don't know how to implement.
A variable SCAN interval can be achieved, for instance, with an mbbo
record that targets the UPDOWN_ record's ODLY field:
record(mbbo,"SCANPERIOD") {
  field(ZRST,"1 minute")
  field(ZRVL,60)
  field(ONST,"1 hour")
  field(ONVL,3600)
  field(NOBT,2)
  field(DTYP,"Raw Soft Channel")
  field(OUT,"UPDOWN_.ODLY")
You should then set UPDOWN_.SCAN to Passive and let it (re-)process
itself via an FLNK that points to itself via CA:
record(calcout, "UPDOWN_" ) {
  field(FLNK,"UPDOWN_.PROC CA")
Be careful not to have ODLY become zero, since this would cause the
record to process in an endless loop eating up all you CPU.
You should also make sure you read the Chapter of the Developer's Guide
about record linking and processing since it seems you misunderstood
what the PP flag does for input links (it looks to me as if you wanted
CPP input links, rather than PP).
BTW, your CALC expression uses assignment and sequencing without need.
Instead of
  field(CALC, "A:=
((D=0)?(A=0?0:(A-B))):((C<(A-B))?(A-B):((A+B)>C?C:(A+B)));A")
you should write:
  field(CALC, "((D=0)?(A=0?0:(A-B))):((C<(A-B))?(A-B):((A+B)>C?C:(A+B)))")
The expression looks as if it should implement a ramp toward the target
value C with an increment of B every time the record processes. This can
indeed be achieved with the ao record's OROC field, which limits the
output rate of change: each time the record is processed, the OVAL is
incremented or decremented towards VAL but no more than OROC. You can
combine this with the variabe SCAN rate trick above, but you'll have to
intersperse a seq record into the processing loop since ao has no ODLY
(or equivalent).
Another way to implement what you want is to write an SNL program (see
http://www-csr.bessy.de/control/SoftDist/sequencer/).
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Attachment: signature.asc
Description: OpenPGP digital signature
Variable SCAN Intervall and Roundoff function info22
Prev: Re: Variable SCAN Intervall and Roundoff function Andrew Johnson
Next: Alias Stefen Paul
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Variable SCAN Intervall and Roundoff function Konrad, Martin
ANJ, 17 Aug 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
