Hi:
On Aug 13, 2016, at 8:24 AM, lzf neu <[email protected]> wrote:
> There are six pv data and I want to display the selected pv data in databrowser by clicking the Check Box widget. I don't know how to make the settings or write script in details in css boy opi or any other methods to cope with this problem.
Ideally, avoid scripts, and do all the processing on the IOC.
Especially when you don’t know how to use scripts, it’s better to avoid them.
If you have several records and you want to select one of them, check the select (“sel”) record, http://www.aps.anl.gov/epics/EpicsDocumentation/AppDevManuals/RecordRef/Recordref-33.html
Somewhat like this:
# PV Shown in a combo box that allows selecting one of the 6 sources
record(mbbi, “choose_one”)
field(ZRVL, “0”)
field(ZRST, “Option A”)
field(ONVL, “1”)
field(ONST, “Option B”)
# Record that will hold the value of one of the six data PVs.
# Simply display this record in the user interface
record(sel, “active_value”)
field(SELM, “Specified”)
field(NVL, “ choose_one”)
field(INPA, “record_for_option_A”)
field(INPB, “record_for_option_A”)
Add FLNK or CP or .. do trigger processing as desired.
-Kay
- Question about data display in css boy opi databrowser lzf neu
RE: synApps 5.8 build issue Mooney, Tim M.
Re: Drawing on XY graph widget without the use of a PV in CSS Kasemir, Kay
<2016>
synApps 5.8 build issue Abdalla Ahmad
<2016>
