Subject: |
Re: Multiple device support for a record type |
Ralph Lange <[email protected]> |
To: |
EPICS Tech Talk <[email protected]> |
Date: |
Thu, 11 Aug 2016 13:38:37 +0200 |
Hi Stefen,
On 11/08/2016 12:39, Stefen Paul wrote:
I've built device support for ai record for a vme based ADC board.
I've used the following to add the support:
device(ai,VME_IO, devAiADCtype1, "HW Channel");
Now I want to build device support for ai record to support one more
type of vme based ADC board to be used in the same system.
How do I do it ? Should I write something like :
device(ai,VME_IO, devAiADCtype2, "HW Channel 2");
Yes, that's the way.
The constraint is that the combination of tag ("HW Channel") and record
type must be unique.
I.e. you can and should support multiple record types for the same
hardware using a single tag.
Please use something descriptive as the tag, e.g. for a VME-6854 card by
MyCorporation something like "MyCorp VME-6854".
If you have multiple functionalities in one support (for one hardware)
that map to the same record type, e.g. different configuration options
and digital outputs that all use a bo record, the distinction is usually
done by a tag in the free text part of the INP/OUT link.
If you need to code more configuration inside a single record instance
than the free text allows, you can add info() structures to the record.
(Be aware, though, that info structures are not visible remotely through
Channel Access.)
Cheers,
~Ralph
- Re: Multiple device support for a record type Stefen Paul
- Multiple device support for a record type Stefen Paul
Re: Multiple device support for a record type Michael Davidsaver
Questions about Data browser in CSS lzf neu
<2016>
<2016>
