I am trying to build EPICS base-3.15.4 on Windows 10 (64-bit) using Visual Studio 10. The build fails with the following messages:
make[3]: *** No rule to make target '../../../lib/windows-x64/Com', needed by 'iocLogServer.exe'. Stop.
make[3]: Leaving directory 'C:/_payload/epics/base-3.15.4/src/libCom/O.windows-x64'
../../configure/RULES_ARCHS:61: recipe for target 'install.windows-x64' failed
make[2]: *** [install.windows-x64] Error 2
make[2]: Leaving directory 'C:/_payload/epics/base-3.15.4/src/libCom'
../configure/RULES_DIRS:88: recipe for target 'libCom.install' failed
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory 'C:/_payload/epics/base-3.15.4/src'
configure/RULES_DIRS:88: recipe for target 'src.install' failed
make: *** [src.install] Error 2
make: Leaving directory 'C:/_payload/epics/base-3.15.4'
I initialized my build environment using:
C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\bin\amd64\vcvars64.bat
I've included artifacts below which I hope will be helpful in diagnosing my problem(s):
# ------- GNU make 4.1 -------------------------------------------------------
GNU Make 4.1
This program is built by Equation Solution <http://www.Equation.com>
for Windows.
Copyright (C) 1988-2014 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
# ------- Strawberry Perl 5, version 24 --------------------------------------
This is perl 5, version 24, subversion 0 (v5.24.0) built for MSWin32-x64-multi-thread
Copyright 1987-2016, Larry Wall
Perl may be copied only under the terms of either the Artistic License or the
GNU General Public License, which may be found in the Perl 5 source kit.
Complete documentation for Perl, including FAQ lists, should be found on
this system using "man perl" or "perldoc perl". If you have access to the
Internet, point your browser at http://www.perl.org/, the Perl Home Page.
# ------- Environment, using EPICS_HOST_ARCH=windows-x64 on Windows 10 -------
ALLUSERSPROFILE=C:\ProgramData
APPDATA=C:\Users\wlee\AppData\Roaming
CommandPromptType=Native
CommonProgramFiles=C:\Program Files\Common Files
CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
CommonProgramW6432=C:\Program Files\Common Files
COMPUTERNAME=TENMAN
ComSpec=C:\Windows\system32\cmd.exe
DISPLAY=LOCALHOST:0.0
EPICS_CA_ADDR_LIST=192.168.0.4
EPICS_CA_AUTO_ADDR_LIST=YES
EPICS_CA_REPEATER_PORT=5065
EPICS_CA_SERVER_PORT=5064
EQ_LIBRARY_PATH=c:\_payload\_tools\gcc\x86_64-w64-mingw32\lib
FPS_BROWSER_APP_PROFILE_STRING=Internet Explorer
FPS_BROWSER_USER_PROFILE_STRING=Default
Framework35Version=v3.5
FrameworkDir=C:\Windows\Microsoft.NET\Framework64
FrameworkDIR64=C:\Windows\Microsoft.NET\Framework64
FrameworkVersion=v4.0.30319
FrameworkVersion64=v4.0.30319
FSHARPINSTALLDIR=c:\Program Files (x86)\Microsoft F#\v4.0\
HOMEDRIVE=C:
HOMEPATH=\Users\wlee
INCLUDE=c:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\INCLUDE;c:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\ATLMFC\INCLUDE;C:\Program Files (x86)\Microsoft SDKs\Windows\v7.0A\include;
LIB=c:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\LIB\amd64;c:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\ATLMFC\LIB\amd64;C:\Program Files (x86)\Microsoft SDKs\Windows\v7.0A\lib\x64;
LIBPATH=C:\Windows\Microsoft.NET\Framework64\v4.0.30319;C:\Windows\Microsoft.NET\Framework64\v3.5;c:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\LIB\amd64;c:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\ATLMFC\LIB\amd64;
LOCALAPPDATA=C:\Users\wlee\AppData\Local
LOGONSERVER=\\TENMAN
MAKEFLAGS=-w
NUMBER_OF_PROCESSORS=2
OS=Windows_NT
Path=c:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\BIN\amd64;C:\Windows\Microsoft.NET\Framework64\v4.0.30319;C:\Windows\Microsoft.NET\Framework64\v3.5;c:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\VCPackages;c:\Program Files (x86)\Microsoft
Visual Studio 10.0\Common7\IDE;c:\Program Files (x86)\Microsoft Visual Studio 10.0\Common7\Tools;C:\Program Files (x86)\HTML Help Workshop;C:\Program Files (x86)\Microsoft SDKs\Windows\v7.0A\bin\NETFX 4.0 Tools\x64;C:\Program Files (x86)\Microsoft SDKs\Windows\v7.0A\bin\x64;C:\Program
Files (x86)\Microsoft SDKs\Windows\v7.0A\bin;C:\_payload\_tools\gcc\bin;C:\_payload\_tools\Strawberry\perl\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\SYSTEM32\Wbem;C:\_payload\epics\base-3.15.4\bin\windows-x64;C:\_payload\epics\_extensions\bin\windows-x64
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
Platform=X64
PROCESSOR_ARCHITECTURE=AMD64
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 23 Stepping 10, GenuineIntel
PROCESSOR_LEVEL=6
PROCESSOR_REVISION=170a
ProgramData=C:\ProgramData
PROMPT=$P$G
PSModulePath=C:\Program Files\WindowsPowerShell\Modules;C:\Windows\system32\WindowsPowerShell\v1.0\Modules
PUBLIC=C:\Users\Public
SESSIONNAME=Console
SystemDrive=C:
SystemRoot=C:\Windows
TEMP=C:\Users\wlee\AppData\Local\Temp
TMP=C:\Users\wlee\AppData\Local\Temp
USERDOMAIN=TENMAN
USERDOMAIN_ROAMINGPROFILE=TENMAN
USERNAME=wlee
USERPROFILE=C:\Users\wlee
VCINSTALLDIR=c:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\
VS100COMNTOOLS=c:\Program Files (x86)\Microsoft Visual Studio 10.0\Common7\Tools\
VSINSTALLDIR=c:\Program Files (x86)\Microsoft Visual Studio 10.0\
windir=C:\Windows
WindowsSdkDir=C:\Program Files (x86)\Microsoft SDKs\Windows\v7.0A\
XERRORDB=C:\Program Files\EPICS Windows Tools\XErrorDB
XKEYSYMDB=C:\Program Files\EPICS Windows Tools\XKeysymDB
XLOCALEDIR=C:\Program Files\EPICS Windows Tools\Locale
# ------- make clean uninstall -----------------------------------------------
make: Entering directory 'C:/_payload/epics/base-3.15.4'
make -C ./configure clean
make[1]: Entering directory 'C:/_payload/epics/base-3.15.4/configure'
perl -CSD -MExtUtils::Command -e rm_rf O.windows-x64 O.Common
make[1]: Leaving directory 'C:/_payload/epics/base-3.15.4/configure'
make -C ./src clean
make[1]: Entering directory 'C:/_payload/epics/base-3.15.4/src'
make -C ./tools clean
make[2]: Entering directory 'C:/_payload/epics/base-3.15.4/src/tools'
make[2]: Leaving directory 'C:/_payload/epics/base-3.15.4/src/tools'
make -C tools/test clean
make[2]: Entering directory 'C:/_payload/epics/base-3.15.4/src/tools/test'
make[2]: Leaving directory 'C:/_payload/epics/base-3.15.4/src/tools/test'
make -C template/base clean
make[2]: Entering directory 'C:/_payload/epics/base-3.15.4/src/template/base'
make[2]: Leaving directory 'C:/_payload/epics/base-3.15.4/src/template/base'
make -C template/ext clean
make[2]: Entering directory 'C:/_payload/epics/base-3.15.4/src/template/ext'
make[2]: Leaving directory 'C:/_payload/epics/base-3.15.4/src/template/ext'
make -C ./libCom clean
make[2]: Entering directory 'C:/_payload/epics/base-3.15.4/src/libCom'
make -C libCom/RTEMS clean
make[2]: Entering directory 'C:/_payload/epics/base-3.15.4/src/libCom/RTEMS'
make[2]: Leaving directory 'C:/_payload/epics/base-3.15.4/src/libCom/RTEMS'
make -C libCom/test clean
make[2]: Entering directory 'C:/_payload/epics/base-3.15.4/src/libCom/test'
make[2]: Leaving directory 'C:/_payload/epics/base-3.15.4/src/libCom/test'
make -C ca/client clean
make[2]: Entering directory 'C:/_payload/epics/base-3.15.4/src/ca/client'
make[2]: Leaving directory 'C:/_payload/epics/base-3.15.4/src/ca/client'
make -C ca/client/tools clean
make[2]: Entering directory 'C:/_payload/epics/base-3.15.4/src/ca/client/tools'
make[2]: Leaving directory 'C:/_payload/epics/base-3.15.4/src/ca/client/tools'
make -C ca/legacy/gdd clean
make[2]: Entering directory 'C:/_payload/epics/base-3.15.4/src/ca/legacy/gdd'
make[2]: Leaving directory 'C:/_payload/epics/base-3.15.4/src/ca/legacy/gdd'
make -C ca/legacy/pcas clean
make[2]: Entering directory 'C:/_payload/epics/base-3.15.4/src/ca/legacy/pcas'
make -C ./build clean
make[3]: Entering directory 'C:/_payload/epics/base-3.15.4/src/ca/legacy/pcas/build'
make[3]: Leaving directory 'C:/_payload/epics/base-3.15.4/src/ca/legacy/pcas/build'
make -C ./example clean
make[3]: Entering directory 'C:/_payload/epics/base-3.15.4/src/ca/legacy/pcas/example'
make -C ./directoryService clean
make[4]: Entering directory 'C:/_payload/epics/base-3.15.4/src/ca/legacy/pcas/example/directoryService'
make[4]: Leaving directory 'C:/_payload/epics/base-3.15.4/src/ca/legacy/pcas/example/directoryService'
make[3]: Leaving directory 'C:/_payload/epics/base-3.15.4/src/ca/legacy/pcas/example'
make[2]: Leaving directory 'C:/_payload/epics/base-3.15.4/src/ca/legacy/pcas'
make -C ./ioc clean
make[2]: Entering directory 'C:/_payload/epics/base-3.15.4/src/ioc'
make[2]: Leaving directory 'C:/_payload/epics/base-3.15.4/src/ioc'
make -C ca/legacy/pcas/ex clean
make[2]: Entering directory 'C:/_payload/epics/base-3.15.4/src/ca/legacy/pcas/ex'
make[2]: Leaving directory 'C:/_payload/epics/base-3.15.4/src/ca/legacy/pcas/ex'
make -C ca/client/perl clean
make[2]: Entering directory 'C:/_payload/epics/base-3.15.4/src/ca/client/perl'
make[2]: Leaving directory 'C:/_payload/epics/base-3.15.4/src/ca/client/perl'
make -C ioc/db/test clean
make[2]: Entering directory 'C:/_payload/epics/base-3.15.4/src/ioc/db/test'
make[2]: Leaving directory 'C:/_payload/epics/base-3.15.4/src/ioc/db/test'
make -C ioc/dbtemplate/test clean
make[2]: Entering directory 'C:/_payload/epics/base-3.15.4/src/ioc/dbtemplate/test'
make[2]: Leaving directory 'C:/_payload/epics/base-3.15.4/src/ioc/dbtemplate/test'
make -C ./std clean
make[2]: Entering directory 'C:/_payload/epics/base-3.15.4/src/std'
make[2]: Leaving directory 'C:/_payload/epics/base-3.15.4/src/std'
make -C std/filters/test clean
make[2]: Entering directory 'C:/_payload/epics/base-3.15.4/src/std/filters/test'
make[2]: Leaving directory 'C:/_payload/epics/base-3.15.4/src/std/filters/test'
make -C std/rec/test clean
make[2]: Entering directory 'C:/_payload/epics/base-3.15.4/src/std/rec/test'
make[2]: Leaving directory 'C:/_payload/epics/base-3.15.4/src/std/rec/test'
perl -CSD -MExtUtils::Command -e rm_rf ./bin/windows-x64
perl -CSD -MExtUtils::Command -e rm_rf ./lib/windows-x64
perl -CSD -MExtUtils::Command -e rm_rf ./dbd ./include ./doc ./html ./templates ./db ./adl ./alh ./cfg ./edl ./lib/perl ./lib/pkgconfig
# ------- EPICS build transcript using Visual Studio 2010 --------------------
make -C ./configure install
perl -CSD ../src/tools/makeMakefile.pl O.windows-x64 ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
make -C O.windows-x64 -f ../Makefile TOP=../.. \
T_A=windows-x64 install
make[2]: Entering directory 'C:/_payload/epics/base-3.15.4/configure/O.windows-x64'
make[2]: Nothing to be done for 'install'.
make[2]: Leaving directory 'C:/_payload/epics/base-3.15.4/configure/O.windows-x64'
make -C ./src install
make -C ./tools install
perl -CSD ../../src/tools/makeMakefile.pl O.windows-x64 ../../..
make -C O.windows-x64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory 'C:/_payload/epics/base-3.15.4/src/tools/O.windows-x64'
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Copy.pm"
mkdir ../../../lib/perl
mkdir ../../../lib/perl/EPICS
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Path.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Release.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Readfile.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Getopts.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/macLib.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Base.pm"
mkdir ../../../lib/perl/DBD
"Installing PERL_MODULES file ../../../lib/perl/DBD/Breaktable.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Device.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Driver.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Function.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Menu.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Output.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Parser.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Recfield.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Recordtype.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Registrar.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Variable.pm"
"Expanding epics-base-windows-x64.pc@ to epics-base-windows-x64.pc"
"Installing PKGCONFIG file ../../../lib/pkgconfig/epics-base-windows-x64.pc"
mkdir ../../../lib/pkgconfig
"Expanding ../epics-base.pc@ to epics-base.pc"
"Installing PKGCONFIG file ../../../lib/pkgconfig/epics-base.pc"
"Installing created executable ../../../bin/windows-x64/assembleSnippets.pl"
mkdir ../../../bin/windows-x64
"Installing created executable ../../../bin/windows-x64/convertRelease.pl"
"Installing created executable ../../../bin/windows-x64/cvsclean.pl"
"Installing created executable ../../../bin/windows-x64/dos2unix.pl"
"Installing created executable ../../../bin/windows-x64/expandVars.pl"
"Installing created executable ../../../bin/windows-x64/fullPathName.pl"
"Installing created executable ../../../bin/windows-x64/installEpics.pl"
"Installing created executable ../../../bin/windows-x64/makeIncludeDbd.pl"
"Installing created executable ../../../bin/windows-x64/makeMakefile.pl"
"Installing created executable ../../../bin/windows-x64/makeTestfile.pl"
"Installing created executable ../../../bin/windows-x64/mkmf.pl"
"Installing created executable ../../../bin/windows-x64/munch.pl"
"Installing created executable ../../../bin/windows-x64/replaceVAR.pl"
"Installing created executable ../../../bin/windows-x64/useManifestTool.pl"
"Installing created executable ../../../bin/windows-x64/dbdToMenuH.pl"
"Installing created executable ../../../bin/windows-x64/dbdToRecordtypeH.pl"
"Installing created executable ../../../bin/windows-x64/dbdExpand.pl"
"Installing created executable ../../../bin/windows-x64/dbdToHtml.pl"
"Installing created executable ../../../bin/windows-x64/podToHtml.pl"
"Installing created executable ../../../bin/windows-x64/podRemove.pl"
"Installing created executable ../../../bin/windows-x64/registerRecordDeviceDriver.pl"
"Installing html ../../../html/./style.css"
mkdir ../../../html
mkdir ../../../html/.
make[3]: Leaving directory 'C:/_payload/epics/base-3.15.4/src/tools/O.windows-x64'
make -C tools/test install
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/makeMakefile.pl O.windows-x64 ../../../..
make -C O.windows-x64 -f ../Makefile TOP=../../../.. \
make[3]: Entering directory 'C:/_payload/epics/base-3.15.4/src/tools/test/O.windows-x64'
perl -CSD -MExtUtils::Command -e cp ../Breaktable.plt Breaktable.t
perl -CSD -MExtUtils::Command -e cp ../DBD.plt DBD.t
perl -CSD -MExtUtils::Command -e cp ../Device.plt Device.t
perl -CSD -MExtUtils::Command -e cp ../Driver.plt Driver.t
perl -CSD -MExtUtils::Command -e cp ../Function.plt Function.t
perl -CSD -MExtUtils::Command -e cp ../macLib.plt macLib.t
perl -CSD -MExtUtils::Command -e cp ../Menu.plt Menu.t
perl -CSD -MExtUtils::Command -e cp ../Recfield.plt Recfield.t
perl -CSD -MExtUtils::Command -e cp ../Recordtype.plt Recordtype.t
perl -CSD -MExtUtils::Command -e cp ../Registrar.plt Registrar.t
perl -CSD -MExtUtils::Command -e cp ../Snippets.plt Snippets.t
perl -CSD -MExtUtils::Command -e cp ../Variable.plt Variable.t
make[3]: Leaving directory 'C:/_payload/epics/base-3.15.4/src/tools/test/O.windows-x64'
make -C template/base install
make[3]: Entering directory 'C:/_payload/epics/base-3.15.4/src/template/base/O.windows-x64'
"Installing created executable ../../../../bin/windows-x64/makeBaseApp.pl"
"Installing ../../../../templates/makeBaseApp/top/Makefile"
mkdir ../../../../templates
mkdir ../../../../templates/makeBaseApp
mkdir ../../../../templates/makeBaseApp/top
"Installing ../../../../templates/makeBaseApp/top/configure/CONFIG"
mkdir ../../../../templates/makeBaseApp/top/configure
"Installing ../../../../templates/makeBaseApp/top/configure/CONFIG_SITE"
"Installing ../../../../templates/makeBaseApp/top/configure/Makefile"
"Installing ../../../../templates/makeBaseApp/top/configure/RELEASE"
"Installing ../../../../templates/makeBaseApp/top/configure/RULES"
"Installing ../../../../templates/makeBaseApp/top/configure/RULES.ioc"
"Installing ../../../../templates/makeBaseApp/top/configure/RULES_DIRS"
"Installing ../../../../templates/makeBaseApp/top/configure/RULES_TOP"
"Installing ../../../../templates/makeBaseApp/top/supportApp/Makefile"
mkdir ../../../../templates/makeBaseApp/top/supportApp
"Installing ../../../../templates/makeBaseApp/top/supportApp/Db/Makefile"
mkdir ../../../../templates/makeBaseApp/top/supportApp/Db
"Installing ../../../../templates/makeBaseApp/top/supportApp/src/Makefile"
mkdir ../../../../templates/makeBaseApp/top/supportApp/src
"Installing ../../../../templates/makeBaseApp/top/supportApp/src/_APPNAME_.dbd"
"Installing ../../../../templates/makeBaseApp/top/iocApp/Makefile"
mkdir ../../../../templates/makeBaseApp/top/iocApp
"Installing ../../../../templates/makeBaseApp/top/iocApp/Db/Makefile"
mkdir ../../../../templates/makeBaseApp/top/iocApp/Db
"Installing ../../../../templates/makeBaseApp/top/iocApp/src/Makefile"
mkdir ../../../../templates/makeBaseApp/top/iocApp/src
"Installing ../../../../templates/makeBaseApp/top/iocApp/src/_APPNAME_Main.cpp"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/Makefile"
mkdir ../../../../templates/makeBaseApp/top/exampleApp
"Installing ../../../../templates/makeBaseApp/top/exampleApp/Db/Makefile"
mkdir ../../../../templates/makeBaseApp/top/exampleApp/Db
"Installing ../../../../templates/makeBaseApp/top/exampleApp/Db/dbExample1.db"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/Db/dbExample2.db"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/Db/dbSubExample.db"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/Db/user.substitutions"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/Makefile"
mkdir ../../../../templates/makeBaseApp/top/exampleApp/src
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.dbd"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.c"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/devXxxSoft.c"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/xxxSupport.dbd"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/sncExample.stt"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/sncProgram.st"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/sncExample.dbd"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.c"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.dbd"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Main.cpp"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.c"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.dbd"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/initTrace.c"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/initTrace.dbd"
"Installing ../../../../templates/makeBaseApp/top/exampleBoot/Makefile"
mkdir ../../../../templates/makeBaseApp/top/exampleBoot
"Installing ../../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@vxWorks"
"Installing ../../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@RTEMS"
"Installing ../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@Common"
mkdir ../../../../templates/makeBaseApp/top/exampleBoot/ioc
"Installing ../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@vxWorks"
"Installing ../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@win32"
"Installing ../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@windows"
"Installing ../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@cygwin"
"Installing ../../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@Common"
"Installing ../../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@vxWorks"
"Installing ../../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@RTEMS"
"Installing ../../../../templates/makeBaseApp/top/exampleBoot/ioc/README@Common"
"Installing ../../../../templates/makeBaseApp/top/exampleBoot/ioc/README@vxWorks"
"Installing ../../../../templates/makeBaseApp/top/caClientApp/Makefile"
mkdir ../../../../templates/makeBaseApp/top/caClientApp
"Installing ../../../../templates/makeBaseApp/top/caClientApp/caExample.c"
"Installing ../../../../templates/makeBaseApp/top/caClientApp/caMonitor.c"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/Makefile"
mkdir ../../../../templates/makeBaseApp/top/caServerApp
"Installing ../../../../templates/makeBaseApp/top/caServerApp/README"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/exAsyncPV.cc"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/exChannel.cc"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/exPV.cc"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/exScalarPV.cc"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/exServer.cc"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/exServer.h"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/exVectorPV.cc"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/main.cc"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/test.adl"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/vxEntry.cc"
"Installing ../../../../templates/makeBaseApp/top/iocBoot/Makefile"
mkdir ../../../../templates/makeBaseApp/top/iocBoot
"Installing ../../../../templates/makeBaseApp/top/iocBoot/nfsCommands@vxWorks"
"Installing ../../../../templates/makeBaseApp/top/iocBoot/nfsCommands@RTEMS"
"Installing ../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@Common"
mkdir ../../../../templates/makeBaseApp/top/iocBoot/ioc
"Installing ../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@vxWorks"
"Installing ../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@win32"
"Installing ../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@windows"
"Installing ../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@cygwin"
"Installing ../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Common"
"Installing ../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Cross"
"Installing ../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@vxWorks"
"Installing ../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@RTEMS"
make[3]: Leaving directory 'C:/_payload/epics/base-3.15.4/src/template/base/O.windows-x64'
make -C template/ext install
make[3]: Entering directory 'C:/_payload/epics/base-3.15.4/src/template/ext/O.windows-x64'
"Installing created executable ../../../../bin/windows-x64/makeBaseExt.pl"
"Installing ../../../../templates/makeBaseExt/top/Makefile"
mkdir ../../../../templates/makeBaseExt
mkdir ../../../../templates/makeBaseExt/top
"Installing ../../../../templates/makeBaseExt/top/README"
"Installing ../../../../templates/makeBaseExt/top/configure/CONFIG"
mkdir ../../../../templates/makeBaseExt/top/configure
"Installing ../../../../templates/makeBaseExt/top/configure/CONFIG_SITE"
"Installing ../../../../templates/makeBaseExt/top/configure/Makefile"
"Installing ../../../../templates/makeBaseExt/top/configure/RELEASE"
"Installing ../../../../templates/makeBaseExt/top/configure/RULES"
"Installing ../../../../templates/makeBaseExt/top/configure/RULES_DIRS"
"Installing ../../../../templates/makeBaseExt/top/configure/RULES_TOP"
"Installing ../../../../templates/makeBaseExt/top/configure/RULES_PYTHON"
"Installing ../../../../templates/makeBaseExt/top/configure/RULES_IDL"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc.aix-ppc"
mkdir ../../../../templates/makeBaseExt/top/configure/os
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64-gnu.solaris-sparc64-gnu"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.freebsd-x86_64.freebsd-x86_64"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-x86.darwin-x86"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG.linux-x86.linux-386"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.cygwin-x86.cygwin-x86"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86_64.solaris-x86_64"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-ppc.linux-ppc"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-debug.solaris-sparc-debug"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.windows-x64.windows-x64"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-debug.win32-x86-debug"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc.solaris-sparc"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86.win32-x86"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-debug.linux-x86-debug"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-cygwin.win32-x86-cygwin"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-x86"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64.solaris-sparc64"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-gnu.solaris-sparc-gnu"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppcx86.darwin-ppcx86"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.Common.Common"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-debug.solaris-x86-debug"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-athlon"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86.solaris-x86"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-gnu.solaris-x86-gnu"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc-gnu.aix-ppc-gnu"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64-debug.linux-x86_64-debug"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-mingw.win32-x86-mingw"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppc.darwin-ppc"
"Installing ../../../../templates/makeBaseExt/top/src/Makefile"
mkdir ../../../../templates/makeBaseExt/top/src
"Installing ../../../../templates/makeBaseExt/top/exampleExt/Makefile"
mkdir ../../../../templates/makeBaseExt/top/exampleExt
"Installing ../../../../templates/makeBaseExt/top/exampleExt/caExample.c"
"Installing ../../../../templates/makeBaseExt/top/exampleExt/RELEASE_NOTES.HTM"
"Installing ../../../../templates/makeBaseExt/top/simpleExt/Makefile"
mkdir ../../../../templates/makeBaseExt/top/simpleExt
make[3]: Leaving directory 'C:/_payload/epics/base-3.15.4/src/template/ext/O.windows-x64'
make -C ./libCom install
make[3]: Entering directory 'C:/_payload/epics/base-3.15.4/src/libCom/O.windows-x64'
perl -CSD ../../../src/libCom/misc/makeEpicsVersion.pl -o epicsVersion.h ../../../configure/CONFIG_BASE_VERSION
Building epicsVersion.h from ../../../configure/CONFIG_BASE_VERSION
Found EPICS Version 3.15.4
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m forceBadAllocException.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
-I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env
-I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi
-I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include
forceBadAllocException.d ../../../src/libCom/osi/os/WIN32/forceBadAllocException.cpp
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m setThreadName.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
setThreadName.d ../../../src/libCom/osi/os/WIN32/setThreadName.cpp
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m epicsGetopt.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
epicsGetopt.d ../../../src/libCom/osi/os/WIN32/epicsGetopt.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m yajl_parser.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
yajl_parser.d ../../../src/libCom/yajl/yajl_parser.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m yajl_lex.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
yajl_lex.d ../../../src/libCom/yajl/yajl_lex.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m yajl_gen.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
yajl_gen.d ../../../src/libCom/yajl/yajl_gen.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m yajl_encode.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
yajl_encode.d ../../../src/libCom/yajl/yajl_encode.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m yajl_buf.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
yajl_buf.d ../../../src/libCom/yajl/yajl_buf.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m yajl_alloc.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
yajl_alloc.d ../../../src/libCom/yajl/yajl_alloc.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m yajl.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I..
yajl.d ../../../src/libCom/yajl/yajl.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m timerQueuePassive.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
timerQueuePassive.d ../../../src/libCom/timer/timerQueuePassive.cpp
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m timerQueueActiveMgr.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
timerQueueActiveMgr.d ../../../src/libCom/timer/timerQueueActiveMgr.cpp
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m timerQueueActive.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
timerQueueActive.d ../../../src/libCom/timer/timerQueueActive.cpp
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m timerQueue.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
timerQueue.d ../../../src/libCom/timer/timerQueue.cpp
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m timer.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
timer.d ../../../src/libCom/timer/timer.cpp
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m epicsTimer.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
epicsTimer.d ../../../src/libCom/timer/epicsTimer.cpp
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m taskwd.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
taskwd.d ../../../src/libCom/taskwd/taskwd.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m epicsRingBytes.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
epicsRingBytes.d ../../../src/libCom/ring/epicsRingBytes.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m epicsRingPointer.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
epicsRingPointer.d ../../../src/libCom/ring/epicsRingPointer.cpp
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m threadPool.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
threadPool.d ../../../src/libCom/pool/threadPool.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m poolJob.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
poolJob.d ../../../src/libCom/pool/poolJob.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m osdFindAddr.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
osdFindAddr.d ../../../src/libCom/osi/os/default/osdFindAddr.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m osdBackTrace.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
osdBackTrace.d ../../../src/libCom/osi/os/WIN32/osdBackTrace.cpp
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m epicsStackTrace.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
epicsStackTrace.d ../../../src/libCom/osi/epicsStackTrace.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m devLibVMEOSD.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
devLibVMEOSD.d ../../../src/libCom/osi/os/default/devLibVMEOSD.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m devLibVME.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
devLibVME.d ../../../src/libCom/osi/devLibVME.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m osdMessageQueue.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
osdMessageQueue.d ../../../src/libCom/osi/os/default/osdMessageQueue.cpp
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m osdNetIntf.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
osdNetIntf.d ../../../src/libCom/osi/os/WIN32/osdNetIntf.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m osdProcess.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
osdProcess.d ../../../src/libCom/osi/os/WIN32/osdProcess.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m osdTime.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
osdTime.d ../../../src/libCom/osi/os/WIN32/osdTime.cpp
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m osdEvent.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
osdEvent.d ../../../src/libCom/osi/os/WIN32/osdEvent.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m osdSpin.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
osdSpin.d ../../../src/libCom/osi/os/default/osdSpin.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m osdMutex.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
osdMutex.d ../../../src/libCom/osi/os/WIN32/osdMutex.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m osdThreadHooks.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
osdThreadHooks.d ../../../src/libCom/osi/os/default/osdThreadHooks.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m osdThreadExtra.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
osdThreadExtra.d ../../../src/libCom/osi/os/WIN32/osdThreadExtra.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m osdThread.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
osdThread.d ../../../src/libCom/osi/os/WIN32/osdThread.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m osdStdio.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
osdStdio.d ../../../src/libCom/osi/os/WIN32/osdStdio.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m epicsStdio.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
epicsStdio.d ../../../src/libCom/osi/epicsStdio.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m epicsTempFile.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
epicsTempFile.d ../../../src/libCom/osi/os/WIN32/epicsTempFile.cpp
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m epicsReadline.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
epicsReadline.d ../../../src/libCom/osi/os/default/epicsReadline.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m osdEnv.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
osdEnv.d ../../../src/libCom/osi/os/default/osdEnv.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m osdSignal.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
osdSignal.d ../../../src/libCom/osi/os/WIN32/osdSignal.cpp
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m osdPoolStatus.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
osdPoolStatus.d ../../../src/libCom/osi/os/WIN32/osdPoolStatus.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m osdInterrupt.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
osdInterrupt.d ../../../src/libCom/osi/os/default/osdInterrupt.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m osdFindSymbol.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
osdFindSymbol.d ../../../src/libCom/osi/os/WIN32/osdFindSymbol.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m osdAssert.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
osdAssert.d ../../../src/libCom/osi/os/default/osdAssert.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m epicsSocketConvertErrnoToString.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
epicsSocketConvertErrnoToString.d ../../../src/libCom/osi/os/WIN32/epicsSocketConvertErrnoToString.cpp
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m systemCallIntMech.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
systemCallIntMech.d ../../../src/libCom/osi/os/WIN32/systemCallIntMech.cpp
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m osiSock.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
osiSock.d ../../../src/libCom/osi/osiSock.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m osdSockAddrReuse.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
osdSockAddrReuse.d ../../../src/libCom/osi/os/WIN32/osdSockAddrReuse.cpp
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m osdSock.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
osdSock.d ../../../src/libCom/osi/os/WIN32/osdSock.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m osiClockTime.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
osiClockTime.d ../../../src/libCom/osi/osiClockTime.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m epicsGeneralTime.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
epicsGeneralTime.d ../../../src/libCom/osi/epicsGeneralTime.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m epicsAtomicOSD.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
epicsAtomicOSD.d ../../../src/libCom/osi/os/default/epicsAtomicOSD.cpp
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m epicsMath.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
epicsMath.d ../../../src/libCom/osi/epicsMath.cpp
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m epicsMessageQueue.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
epicsMessageQueue.d ../../../src/libCom/osi/epicsMessageQueue.cpp
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m epicsTime.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
epicsTime.d ../../../src/libCom/osi/epicsTime.cpp
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m epicsEvent.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
epicsEvent.d ../../../src/libCom/osi/epicsEvent.cpp
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m epicsMutex.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
epicsMutex.d ../../../src/libCom/osi/epicsMutex.cpp
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m epicsThread.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
epicsThread.d ../../../src/libCom/osi/epicsThread.cpp
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m epicsUnitTest.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
epicsUnitTest.d ../../../src/libCom/misc/epicsUnitTest.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m ipAddrToAsciiAsynchronous.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
ipAddrToAsciiAsynchronous.d ../../../src/libCom/misc/ipAddrToAsciiAsynchronous.cpp
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m truncateFile.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
truncateFile.d ../../../src/libCom/misc/truncateFile.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m epicsString.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
epicsString.d ../../../src/libCom/misc/epicsString.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m epicsStdlib.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
epicsStdlib.d ../../../src/libCom/misc/epicsStdlib.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m epicsExit.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
epicsExit.d ../../../src/libCom/misc/epicsExit.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m epicsConvert.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
epicsConvert.d ../../../src/libCom/misc/epicsConvert.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m cantProceed.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
cantProceed.d ../../../src/libCom/misc/cantProceed.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m adjustment.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
adjustment.d ../../../src/libCom/misc/adjustment.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m aToIPAddr.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
aToIPAddr.d ../../../src/libCom/misc/aToIPAddr.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m alarmString.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
alarmString.d ../../../src/libCom/misc/alarmString.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m macUtil.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
macUtil.d ../../../src/libCom/macLib/macUtil.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m macEnv.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
macEnv.d ../../../src/libCom/macLib/macEnv.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m macCore.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
macCore.d ../../../src/libCom/macLib/macCore.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m logClient.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
logClient.d ../../../src/libCom/log/logClient.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m iocLog.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
iocLog.d ../../../src/libCom/log/iocLog.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m libComRegister.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
libComRegister.d ../../../src/libCom/iocsh/libComRegister.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m registry.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
registry.d ../../../src/libCom/iocsh/registry.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m iocsh.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
iocsh.d ../../../src/libCom/iocsh/iocsh.cpp
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m gpHashLib.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
gpHashLib.d ../../../src/libCom/gpHash/gpHashLib.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m freeListLib.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
freeListLib.d ../../../src/libCom/freeList/freeListLib.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m fdManager.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
fdManager.d ../../../src/libCom/fdmgr/fdManager.cpp
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m fdmgr.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
fdmgr.d ../../../src/libCom/fdmgr/fdmgr.cpp
perl -CSD ../../../src/libCom/error/makeStatTbl.pl ../../../src/libCom/osi/devLib.h ../../../src/libCom/as/asLib.h ../../../src/libCom/misc/epicsStdlib.h ../../../src/libCom/pool/epicsThreadPool.h ../../../src/ioc/db/dbAccessDefs.h ../../../src/ioc/dbStatic/devSup.h
../../../src/ioc/dbStatic/drvSup.h ../../../src/ioc/dbStatic/recSup.h ../../../src/ioc/dbStatic/dbStaticLib.h ../../../src/libCom/error/errMdef.h ../../../src/ca/legacy/pcas/generic/casdef.h ../../../src/ca/legacy/gdd/gddAppFuncTable.h
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m errSymTbl.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
errSymTbl.d errSymTbl.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m errSymLib.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
errSymLib.d ../../../src/libCom/error/errSymLib.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m errlog.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
errlog.d ../../../src/libCom/error/errlog.c
perl -CSD ../../../src/libCom/env/bldEnvData.pl -t windows-x64 \
-c msvc -s WIN32 ../../../configure
Generating envData.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m envData.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
envData.d envData.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m envSubr.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
envSubr.d ../../../src/libCom/env/envSubr.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m ellLib.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
ellLib.d ../../../src/libCom/ellLib/ellLib.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m dbmf.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I..
dbmf.d ../../../src/libCom/dbmf/dbmf.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m epicsSingletonMutex.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
epicsSingletonMutex.d ../../../src/libCom/cxxTemplates/epicsSingletonMutex.cpp
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m epicsOnce.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
epicsOnce.d ../../../src/libCom/cxxTemplates/epicsOnce.cpp
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m resourceLib.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
resourceLib.d ../../../src/libCom/cxxTemplates/resourceLib.cpp
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m cvtFast.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
cvtFast.d ../../../src/libCom/cvtFast/cvtFast.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m calcPerform.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
calcPerform.d ../../../src/libCom/calc/calcPerform.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m postfix.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
postfix.d ../../../src/libCom/calc/postfix.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m bucketLib.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
bucketLib.d ../../../src/libCom/bucketLib/bucketLib.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m asTrapWrite.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
asTrapWrite.d ../../../src/libCom/as/asTrapWrite.c
"Installing generic include file ../../../include/asLib.h"
mkdir ../../../include
"Installing generic include file ../../../include/asTrapWrite.h"
"Installing generic include file ../../../include/bucketLib.h"
"Installing generic include file ../../../include/postfix.h"
"Installing generic include file ../../../include/cvtFast.h"
"Installing generic include file ../../../include/epicsAlgorithm.h"
"Installing generic include file ../../../include/epicsExcept.h"
"Installing generic include file ../../../include/epicsMemory.h"
"Installing generic include file ../../../include/resourceLib.h"
"Installing generic include file ../../../include/tsDLList.h"
"Installing generic include file ../../../include/tsSLList.h"
"Installing generic include file ../../../include/tsMinMax.h"
"Installing generic include file ../../../include/tsBTree.h"
"Installing generic include file ../../../include/tsFreeList.h"
"Installing generic include file ../../../include/epicsSingleton.h"
"Installing generic include file ../../../include/epicsGuard.h"
"Installing generic include file ../../../include/epicsOnce.h"
"Installing generic include file ../../../include/dbmf.h"
"Installing generic include file ../../../include/ellLib.h"
"Installing generic include file ../../../include/envDefs.h"
"Installing generic include file ../../../include/epicsPrint.h"
"Installing generic include file ../../../include/errMdef.h"
"Installing generic include file ../../../include/errSymTbl.h"
"Installing generic include file ../../../include/errlog.h"
"Installing generic include file ../../../include/error.h"
"Installing generic include file ../../../include/fdManager.h"
"Installing generic include file ../../../include/fdmgr.h"
"Installing generic include file ../../../include/flex.skel.static"
"Installing generic include file ../../../include/freeList.h"
"Installing generic include file ../../../include/gpHash.h"
"Installing generic include file ../../../include/iocsh.h"
"Installing generic include file ../../../include/registry.h"
"Installing generic include file ../../../include/libComRegister.h"
"Installing generic include file ../../../include/iocLog.h"
"Installing generic include file ../../../include/logClient.h"
"Installing generic include file ../../../include/macLib.h"
"Installing generic include file ../../../include/alarm.h"
"Installing generic include file ../../../include/alarmString.h"
"Installing generic include file ../../../include/adjustment.h"
"Installing generic include file ../../../include/cantProceed.h"
"Installing generic include file ../../../include/dbDefs.h"
"Installing generic include file ../../../include/epicsConvert.h"
"Installing generic include file ../../../include/epicsExit.h"
"Installing generic include file ../../../include/epicsStdlib.h"
"Installing generic include file ../../../include/epicsString.h"
"Installing generic include file ../../../include/epicsTypes.h"
"Installing generic include file ../../../include/shareLib.h"
"Installing generic include file ../../../include/epicsExport.h"
"Installing generic include file ../../../include/unixFileName.h"
"Installing generic include file ../../../include/locationException.h"
"Installing generic include file ../../../include/ipAddrToAsciiAsynchronous.h"
"Installing generic include file ../../../include/compilerDependencies.h"
"Installing generic include file ../../../include/epicsUnitTest.h"
"Installing generic include file ../../../include/testMain.h"
"Installing generated generic include file ../../../include/epicsVersion.h"
"Installing compiler dependent include file ../../../include/compiler/msvc/compilerSpecific.h"
mkdir ../../../include/compiler
mkdir ../../../include/compiler/msvc
"Installing OS dependent include file ../../../include/os/WIN32/osiFileName.h"
mkdir ../../../include/os
mkdir ../../../include/os/WIN32
"Installing generic include file ../../../include/osiSock.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdSock.h"
"Installing generic include file ../../../include/epicsInterrupt.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdInterrupt.h"
"Installing generic include file ../../../include/epicsMutex.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdMutex.h"
"Installing generic include file ../../../include/epicsSpin.h"
"Installing generic include file ../../../include/epicsEvent.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdEvent.h"
"Installing OS dependent include file ../../../include/os/WIN32/epicsMath.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdMessageQueue.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdStrtod.h"
"Installing generic include file ../../../include/epicsAssert.h"
"Installing generic include file ../../../include/epicsFindSymbol.h"
"Installing generic include file ../../../include/osiPoolStatus.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdPoolStatus.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdThread.h"
"Installing generic include file ../../../include/epicsThread.h"
"Installing generic include file ../../../include/epicsTime.h"
"Installing generic include file ../../../include/epicsGeneralTime.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdTime.h"
"Installing generic include file ../../../include/generalTimeSup.h"
"Installing generic include file ../../../include/osiClockTime.h"
"Installing generic include file ../../../include/epicsSignal.h"
"Installing generic include file ../../../include/osiProcess.h"
"Installing OS dependent include file ../../../include/os/WIN32/osiUnistd.h"
"Installing generic include file ../../../include/osiWireFormat.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdWireFormat.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdWireConfig.h"
"Installing generic include file ../../../include/epicsAtomic.h"
"Installing generic include file ../../../include/epicsAtomicDefault.h"
"Installing OS dependent include file ../../../include/os/WIN32/epicsAtomicOSD.h"
"Installing compiler dependent include file ../../../include/compiler/msvc/epicsAtomicCD.h"
"Installing generic include file ../../../include/epicsEndian.h"
"Installing OS dependent include file ../../../include/os/WIN32/epicsReadline.h"
"Installing generic include file ../../../include/epicsMessageQueue.h"
"Installing generic include file ../../../include/epicsStdio.h"
"Installing generic include file ../../../include/epicsStdioRedirect.h"
"Installing generic include file ../../../include/epicsTempFile.h"
"Installing OS dependent include file ../../../include/os/WIN32/epicsGetopt.h"
"Installing generic include file ../../../include/epicsStackTrace.h"
"Installing generic include file ../../../include/devLib.h"
"Installing generic include file ../../../include/devLibVME.h"
"Installing generic include file ../../../include/devLibVMEImpl.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdVME.h"
"Installing OS dependent include file ../../../include/os/WIN32/epicsMMIO.h"
"Installing OS dependent include file ../../../include/os/WIN32/epicsMMIODef.h"
"Installing generic include file ../../../include/epicsThreadPool.h"
"Installing generic include file ../../../include/epicsRingPointer.h"
"Installing generic include file ../../../include/epicsRingBytes.h"
"Installing generic include file ../../../include/taskwd.h"
"Installing generic include file ../../../include/epicsTimer.h"
"Installing generic include file ../../../include/yajl_common.h"
"Installing generic include file ../../../include/yajl_gen.h"
"Installing generic include file ../../../include/yajl_parse.h"
"Installing OS dependent include file ../../../include/os/WIN32/epicsAtomicMS.h"
cl -EHsc -GR -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -MT -TP -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I.
-I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf
-I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib
-I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc
-I../../../include/os/WIN32 -I../../../include -c ../../../src/libCom/osi/os/WIN32/epicsTempFile.cpp
epicsTempFile.cpp
cl -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -MT -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32
-I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib
-I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc
-I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32
-I../../../include -c ../../../src/libCom/flex/ccl.c
ccl.c
-I../../../include -c ../../../src/libCom/flex/dfa.c
dfa.c
-I../../../include -c ../../../src/libCom/flex/ecs.c
ecs.c
-I../../../include -c ../../../src/libCom/flex/gen.c
gen.c
-I../../../include -c ../../../src/libCom/flex/misc.c
misc.c
-I../../../include -c ../../../src/libCom/flex/nfa.c
nfa.c
-I../../../include -c ../../../src/libCom/flex/sym.c
sym.c
-I../../../include -c ../../../src/libCom/flex/tblcmp.c
tblcmp.c
-I../../../include -c ../../../src/libCom/yacc/closure.c
closure.c
-I../../../include -c ../../../src/libCom/yacc/error.c
error.c
-I../../../include -c ../../../src/libCom/yacc/lalr.c
lalr.c
-I../../../include -c ../../../src/libCom/yacc/lr0.c
lr0.c
../../../src/libCom/yacc/lr0.c(186) : warning C4244: '=' : conversion from '__int64' to 'int', possible loss of data
../../../src/libCom/yacc/lr0.c(314) : warning C4244: '=' : conversion from '__int64' to 'int', possible loss of data
-I../../../include -c ../../../src/libCom/yacc/antelope.c
antelope.c
../../../src/libCom/yacc/antelope.c(238) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
-I../../../include -c ../../../src/libCom/yacc/mkpar.c
mkpar.c
-I../../../include -c ../../../src/libCom/yacc/output.c
output.c
../../../src/libCom/yacc/output.c(1019) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
-I../../../include -c ../../../src/libCom/yacc/reader.c
reader.c
../../../src/libCom/yacc/reader.c(1531) : warning C4267: '+=' : conversion from 'size_t' to 'int', possible loss of data
../../../src/libCom/yacc/reader.c(1769) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
-I../../../include -c ../../../src/libCom/yacc/skeleton.c
skeleton.c
-I../../../include -c ../../../src/libCom/yacc/symtab.c
symtab.c
-I../../../include -c ../../../src/libCom/yacc/verbose.c
verbose.c
-I../../../include -c ../../../src/libCom/yacc/warshall.c
warshall.c
link -nologo -LTCG -incremental:no -opt:ref -release -version:3.15 /MACHINE:X64 -out:antelope.exe epicsTempFile.obj closure.obj error.obj lalr.obj lr0.obj antelope.obj mkpar.obj output.obj reader.obj skeleton.obj symtab.obj verbose.obj warshall.obj
ws2_32.lib advapi32.lib user32.lib kernel32.lib winmm.lib
Generating code
Finished generating code
"Installing created executable ../../../bin/windows-x64/antelope.exe"
C:/_payload/epics/base-3.15.4/bin/windows-x64/antelope.exe -bparse -l -d ../../../src/libCom/flex/parse.y
perl -CSD -MExtUtils::Command -e mv parse.tab.c parse.c
perl -CSD -MExtUtils::Command -e mv parse.tab.h parse.h
cl -DDEFAULT_SKELETON_FILE=flex.skel.static -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -MT -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default
-I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates
-I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log
-I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl
-I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c parse.c
parse.c
scan.l(935) : warning C4244: '=' : conversion from '__int64' to 'int', possible loss of data
scan.l(180) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
scan.l(240) : warning C4244: '=' : conversion from '__int64' to 'int', possible loss of data
scan.l(269) : warning C4244: '=' : conversion from '__int64' to 'int', possible loss of data
scan.l(271) : warning C4244: '=' : conversion from '__int64' to 'int', possible loss of data
scan.l(326) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
scan.l(347) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
scan.l(363) : warning C4244: '=' : conversion from '__int64' to 'int', possible loss of data
scan.l(379) : warning C4244: '=' : conversion from '__int64' to 'int', possible loss of data
scan.l(382) : warning C4244: '=' : conversion from '__int64' to 'int', possible loss of data
scan.l(385) : warning C4244: '=' : conversion from '__int64' to 'int', possible loss of data
scan.l(513) : warning C4244: 'initializing' : conversion from '__int64' to 'int', possible loss of data
scan.l(649) : warning C4244: '=' : conversion from '__int64' to 'int', possible loss of data
scan.l(805) : warning C4244: '=' : conversion from '__int64' to 'int', possible loss of data
link -nologo -LTCG -incremental:no -opt:ref -release -version:3.15 /MACHINE:X64 -out:e_flex.exe epicsTempFile.obj ccl.obj dfa.obj ecs.obj gen.obj misc.obj nfa.obj sym.obj tblcmp.obj parse.obj ws2_32.lib advapi32.lib user32.lib kernel32.lib
winmm.lib
Generating code
"Installing created executable ../../../bin/windows-x64/e_flex.exe"
C:/_payload/epics/base-3.15.4/bin/windows-x64/e_flex.exe -S../../../include/flex.skel.static -8 -I -t ../../../src/libCom/as/asLib_lex.l > asLib_lex.yy.c
perl -CSD -MExtUtils::Command -e mv asLib_lex.yy.c asLib_lex.c
C:/_payload/epics/base-3.15.4/bin/windows-x64/antelope.exe -basLib ../../../src/libCom/as/asLib.y
perl -CSD -MExtUtils::Command -e mv asLib.tab.c asLib.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m asLib.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
asLib.d asLib.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m warshall.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
warshall.d ../../../src/libCom/yacc/warshall.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m verbose.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
verbose.d ../../../src/libCom/yacc/verbose.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m symtab.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
symtab.d ../../../src/libCom/yacc/symtab.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m skeleton.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
skeleton.d ../../../src/libCom/yacc/skeleton.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m reader.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
reader.d ../../../src/libCom/yacc/reader.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m output.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
output.d ../../../src/libCom/yacc/output.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m mkpar.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
mkpar.d ../../../src/libCom/yacc/mkpar.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m antelope.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
antelope.d ../../../src/libCom/yacc/antelope.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m lr0.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I..
lr0.d ../../../src/libCom/yacc/lr0.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m lalr.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I..
lalr.d ../../../src/libCom/yacc/lalr.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m error.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
error.d ../../../src/libCom/yacc/error.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m closure.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
closure.d ../../../src/libCom/yacc/closure.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m iocLogServer.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
iocLogServer.d ../../../src/libCom/log/iocLogServer.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m parse.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
parse.d parse.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m tblcmp.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
tblcmp.d ../../../src/libCom/flex/tblcmp.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m sym.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I..
sym.d ../../../src/libCom/flex/sym.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m nfa.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I..
nfa.d ../../../src/libCom/flex/nfa.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m misc.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I..
misc.d ../../../src/libCom/flex/misc.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m gen.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I..
gen.d ../../../src/libCom/flex/gen.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m ecs.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I..
ecs.d ../../../src/libCom/flex/ecs.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m dfa.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I..
dfa.d ../../../src/libCom/flex/dfa.c
perl -CSD C:/_payload/epics/base-3.15.4/bin/windows-x64/mkmf.pl -m ccl.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I..
ccl.d ../../../src/libCom/flex/ccl.c
-I../../../include -c ../../../src/libCom/log/iocLogServer.c
iocLogServer.c
../../../src/libCom/log/iocLogServer.c(418) : warning C4244: 'function' : conversion from 'SOCKET' to 'int', possible loss of data
make[3]: *** No rule to make target '../../../lib/windows-x64/Com', needed by 'iocLogServer.exe'. Stop.
make[3]: Leaving directory 'C:/_payload/epics/base-3.15.4/src/libCom/O.windows-x64'
../../configure/RULES_ARCHS:61: recipe for target 'install.windows-x64' failed
make[2]: *** [install.windows-x64] Error 2
make[2]: Leaving directory 'C:/_payload/epics/base-3.15.4/src/libCom'
../configure/RULES_DIRS:88: recipe for target 'libCom.install' failed
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory 'C:/_payload/epics/base-3.15.4/src'
configure/RULES_DIRS:88: recipe for target 'src.install' failed
make: *** [src.install] Error 2
make: Leaving directory 'C:/_payload/epics/base-3.15.4'
# ------- END transcript -------
Thanks for your assistance! :-)
Bill
William R Lee, Systems Analyst
Jacobs Technology, Inc., JTOG Business Segment
[email protected] | 757-864-8546 (TEL)
Any opinion expressed in this message is my own and not that of NASA.
