1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: CA connection problems between VxWorks and Windows
To: Benjamin Franksen <[email protected]>
Date: Mon, 8 Aug 2016 13:41:17 +0000
> On Aug 8, 2016, at 7:44 AM, Benjamin Franksen <[email protected]> wrote:
> The strange thing is that it works if we use EPICS_CA_ADDR_LIST to ask a
> CA gateway in /another/ network, but not if we connect to the VxWorks
> IOC (in the same network) directly. We can also conect to channels from
> soft IOCs runing on a linux host in the same network. Finally, replacing
> the Windows machine with a linux host with the same IP and connected to
> the same port of the same switch works flawless. I may be wrong but I
> think this rules out interference from any of the network components.
Hi Ben—
Perhaps the arp table is getting corrupted by some mis-behaving device on the network. That could explain the 15 minute recovery time. Try running ‘arpShow’ and ‘inetstatShow’ on the VxWorks box, and ‘arp -a’ and ‘netstat -a -n’ on the Windows box, both when it is working and when it is not.
Even more useful would be to run something like wireshark on the Windows box to see what is happening on the network.
Steven Hartman
[email protected]
CA connection problems between VxWorks and Windows Benjamin Franksen
Re: CA connection problems between VxWorks and Windows Michael Davidsaver
Re: CA connection problems between VxWorks and Windows Benjamin Franksen
Prev: Re: CA connection problems between VxWorks and Windows Mark Rivers
Next: Re: CA connection problems between VxWorks and Windows Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: CA connection problems between VxWorks and Windows Benjamin Franksen
ANJ, 31 Oct 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
