1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Error in interfacing gigE camera make: Balser
Date: Mon, 8 Aug 2016 12:40:29 +0000
I think you should be able to use the aravisGige drivers from areaDetector. It may give you more features than the Sesame driver you trying now.
Sent from my iPhone
> On Aug 8, 2016, at 3:01 AM, "[email protected]" <[email protected]> wrote:
> Hi,
>   I am trying to start an epics driver for Basler scA-1390-17gc camera.
> I copied the github repository from
> https://github.com/sesamecs/basler-gige.git
> I installed pylon3 in /opt directory and started camera with Pylonveiwer.
> But when I start epics driver from the above repository following error
> messages are shown.
> Exception: Failed to write enumeration value. Enum entry is not
> writableUnable to initialize driver thread
> Unable to read BOC03-DI-CAM1:getExposure: Driver thread is unable to read
> Unable to read BOC03-DI-CAM1:getGain: Driver thread is unable to read
> Unable to read BOC03-DI-CAM1:getHeight: Driver thread is unable to read
> Unable to read BOC03-DI-CAM1:getSize: Driver thread is unable to read
> Unable to read BOC03-DI-CAM1:getOffsetY: Driver thread is unable to read
> Unable to read BOC03-DI-CAM1:getWidth: Driver thread is unable to read
> Unable to read BOC03-DI-CAM1:getGainAuto: Driver thread is unable to read
> Unable to read BOC03-DI-CAM1:getOffsetX: Driver thread is unable to read
> Unable to read BOC03-DI-CAM1:getTriggerSource: Driver thread is unable to
> read
> apart from these I am also getting error
> "../../../src/ioc/rsrv/online_notify.c: CA beacon (send to
> "127.0.0.1:5065") error was "Connection refused"
> Please duide me how to start this epics driver.
> Thank you
Error in interfacing gigE camera make: Balser avanish
Prev: Re: Drawing on XY graph widget without the use of a PV in CSS Márcio Paduan Donadio
Next: Re: Epics-Digitizer Communication Hulusi Öz
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Error in interfacing gigE camera make: Balser avanish
Next: Drawing on XY graph widget without the use of a PV in CSS Abdalla Ahmad
ANJ, 08 Aug 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
