1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Drawing on XY graph widget without the use of a PV in CSS
Cc: Márcio Paduan Donadio <[email protected]>
Date: Mon, 8 Aug 2016 12:38:06 +0000
    You can use loc variables in X PV and Y PV parameters. Eg: loc://x and loc://y.
    Inside the script you can do something like this:
from java.util import Arrays
from jarray import zeros
from java.lang import Double
x = zeros(NUM_OF_STEPS, Double)
y = zeros(NUM_OF_STEPS, Double)
for i in range (NUM_OF_STEPS):
    x[i] = 0
    y[i] = 0
# Do processing....
pvs[0].setValue(x)
pvs[1].setValue(y)
Engenheiro de Computação - Software de Operação das Linhas de Luz
Laboratório Nacional de Luz Síncrotron – (LNLS)
Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
+ 55 (19) 3512-3520 - [email protected]
www.lnls.cnpem.br
Hello
Is it possible to draw some data on an XY graph widget from a script/rule without using a PV? I mainly tried setting the property 'pv_value' but nothing appears on the graph. I'm not sure if this is even possible or not. The thing is I will receive a waveform PV value and I want to do some processing on it then displaying the output on the XY graph.
Best Regards,
Abdalla.
RE: Drawing on XY graph widget without the use of a PV in CSS Abdalla Ahmad
Prev: Re: Epics-Digitizer Communication Mark Rivers
Next: Re: Error in interfacing gigE camera make: Balser Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Drawing on XY graph widget without the use of a PV in CSS Abdalla Ahmad
Next: RE: Drawing on XY graph widget without the use of a PV in CSS Abdalla Ahmad
ANJ, 10 Aug 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
