Hi Kay, I've managed to go over this exercise the other day. I had most problems in getting the development environment set up on my side, otherwise it is smooth sailing.On Thu, Aug 4, 2016 at 3:06 PM, Kasemir, Kay <[email protected]> wrote:
-- .. the more I see the less I believe.., AE AoR
MCA on windows 7, 64-bit Download and install 7zip (http://www.7-zip.org/download.html) Download and install Make (http://gnuwin32.sourceforge.net/packages/make.htm) Download and install Perl (http://strawberryperl.com/) Install Matlab 2016a (if not already installed) Download and install Microsoft Windows SDK v7.1 http://se.mathworks.com/matlabcentral/answers/101105-how-do-i-install-microsoft-windows-sdk-7-1?requestedDomain=www.mathworks.com https://www.microsoft.com/en-us/download/details.aspx?id=8279 - Microsoft Windows SDK for Windows 7 and .NET Framework 4 If it complains about .NET 4 missing, follow the instructions on first link. I did not reinstall .NET 4.5 after installing SDK v7.1, that I had to remove in my case. Compile EPICS base 3.14.12.5 Get the sources http://www.aps.anl.gov/epics/download/base/baseR3.14.12.5.tar.gz Extract to c:\ Set EPICS_HOST_ARCH in Environment Variables, System Variables to EPICS_HOST_ARCH=windows-x64 Open cmd Setup 64-bit compiler (see http://stackoverflow.com/questions/20829477/vcvars64-bat-file-is-missing) No vcvarsall.bat et. al. needed, just run following command CALL "c:\Program Files\Microsoft SDKs\Windows\v7.1\Bin\SetEnv.Cmd" /x64 cmd text turns yellow Check compiler version that it shows "x64" cl \h Microsoft (R) C/C++ Optimizing Compiler Version 16.00.30319.01 for x64 Copyright (C) Microsoft Corporation. All rights reserved. Adjust LINK_OPT_FLAGS_YES in base-3.14.12.5\configure\os\CONFIG.win32-x86.win32-x86 Look for "LINK_OPT_FLAGS_YES" and add "/MANIFEST" New content: LINK_OPT_FLAGS_YES = /MANIFEST /LTCG /incremental:no /opt:ref /release $(PROD_VERSION:%=/version:%) Compile EPICS base cd c:\base-3.14.12.5 "c:\Program Files (x86)\GnuWin32\bin\make.exe" Download and compile MCA sources (https://ics-web.sns.ornl.gov/kasemir/mca/index.html) At this time R4-4 is latest stable Extract to Matlab toolbox folder Setup MEX C compiler mex -setup -v [...] Found installed compiler 'Microsoft Windows SDK 7.1 (C)'. MEX configured to use 'Microsoft Windows SDK 7.1 (C)' for C language compilation. Setup MEX C++ compiler mex -setup -v c++ [...] Found installed compiler 'Microsoft Windows SDK 7.1 (C++)'. MEX configured to use 'Microsoft Windows SDK 7.1 (C++)' for C++ language compilation. Compile MCA Make sure that -DEPICS_NO_DLL is *NOT* specified! Otherwise linking fails due to some missing symbols! cd c:\MATLAB\R2016a\toolbox\mca-R4-4 mex mca.cpp MCAError.cpp Channel.cpp c:\base-3.14.12.5\lib\windows-x64\Com.lib c:\base-3.14.12.5\lib\windows-x64\ca.lib -DDB_TEXT_GLBLSOURCE -DMSCC -DWIN32 -DWIN64 -Ic:\base-3.14.12.5\include -Ic:\base-3.14.12.5\include\os\WIN32 -v Should have 'mca.mexw64' if all goes well! Setup PATH in Environment Variables, System Variables to hold EPICS paths ... ;C:\base-3.14.12.5\bin\windows-x64;C:\base-3.14.12.5\lib\windows-x64 Start matlab Add paths to MCA >> addpath c:\MATLAB\R2016a\toolbox\mca-R4-4 >> addpath c:\MATLAB\R2016a\toolbox\mca-R4-4\matlab Get PV value >> pv=mcaopen('LLRF:OPMODE') MCA Initialized pv = 1 >> mcaget(pv) ans = 4 DONE! Attachment:
ANJ, 05 Aug 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
