Hi Ali,
The windows-x64-static target is just a predefined way of doing exactly what you do, there should be no difference in the result. We originally added that target so we could easily run test-builds of both static and dynamic Windows
targets on our Jenkins CI server side-by-side.
- Andrew
Sent from my iPad
Hi Mark,
Ok. To build base as static I normally just set STATIC_BUILD=YES and SHARED_LIBRARIES=NO in $(EPICS_BASE)/configure/CONFIG_SITE and then set EPICS_HOST_ARCH=windows-x64. This results
in no dlls being built in the bin directory of EPICS_BASE. I did not know I had to set it as windows-x64-static even when I set static build as YES. I will recompile by setting the arch as windows-x64-static and see if that works.
Thanks for your help.
Best,
Ali
- Re: compile error in ADExample/simDetector with opencv Alireza Panna
- compile error in ADExample/simDetector with opencv Alireza Panna
- Re: compile error in ADExample/simDetector with opencv Mark Rivers
<2016>
<2016>
ANJ, 03 Aug 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
