Hi Mark, Ok. To build base as static I normally just set STATIC_BUILD=YES and SHARED_LIBRARIES=NO in $(EPICS_BASE)/configure/CONFIG_SITE and then set EPICS_HOST_ARCH=windows-x64. This results in no dlls being built in the bin directory of EPICS_BASE. I did not know I had to set it as windows-x64-static even when I set static build as YES. I will recompile by setting the arch as windows-x64-static and see if that works. Thanks for your help. Best, Ali On Wed, Aug 3, 2016 at 9:11 PM, Mark Rivers <[email protected]> wrote: By dynamic I mean that you are building windows-x64 rather than windows-x64-static. By default that is a dynamic (using dlls) build.
ANJ, 03 Aug 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
