By dynamic I mean that you are building windows-x64 rather than windows-x64-static. By default that is a dynamic (using dlls) build.
Sent from my iPhone
On Aug 3, 2016, at 5:17 PM, Alireza Panna <[email protected]<mailto:[email protected]>> wrote:
Hi Mark,
Thanks for the quick reply. I added this in the commonLibraryMakefile:
ifdef ADPLUGINEDGE
ifdef OPENCV_LIB
opencv_core_DIR += $(OPENCV_LIB)
LIB_LIBS += opencv_world310
else
LIB_SYS_LIBS += opencv_world310
endif
endif
now in the commonDriverMakefile, i just have the following:
ifdef ADPLUGINEDGE
PROD_LIBS += NDPluginEdge
$(PROD_NAME)_DBD += NDPluginEdge.dbd
endif
I get the following error now after doing make realclean realuninstall && make
NDPluginEdge.lib(NDPluginEdge.obj) : error LNK2001: unresolved external symbol "
void __cdecl cv::blur(class cv::_InputArray const &,class cv::_OutputArray const
&,class cv::Size_<int>,class cv::Point_<int>,int)" (?blur@cv@@YAXAEBV_InputArra
y@1@AEBV_OutputArray@1@V?$Size_@H@1@V?$Point_@H@1@H@Z)
void __cdecl cv::fastFree(void *)" (?fastFree@cv@@YAXPEAX@Z)
public: void __cdecl cv::Mat::deallocate(void)" (?deallocate@Mat@cv@@QEAAXXZ)
public: void __cdecl cv::Mat::create(int,int const *,int)" (?create@Mat@cv@@QEAA
XHPEBHH@Z)
void __cdecl cv::Canny(class cv::_InputArray const &,class cv::_OutputArray cons
t &,double,double,int,bool)" (?Canny@cv@@YAXAEBV_InputArray@1@AEBV_OutputArray@1
@NNH_N@Z)
ADCSimDetectorApp.exe : fatal error LNK1120: 5 unresolved externals
make[6]: *** [ADCSimDetectorApp.exe] Error 1120
make[6]: Leaving directory `C:/Epics/support/areaDetector-2-4/ADExample/iocs/ADC
SimDetectorIOC/ADCSimDetectorApp/src/O.windows-x64'
make[5]: *** [install.windows-x64] Error 2
make[5]: Leaving directory `C:/Epics/support/areaDetector-2-4/ADExample/iocs/ADC
SimDetectorIOC/ADCSimDetectorApp/src'
make[4]: *** [src.install] Error 2
make[4]: Leaving directory `C:/Epics/support/areaDetector-2-4/ADExample/iocs/ADC
SimDetectorIOC/ADCSimDetectorApp'
make[3]: *** [ADCSimDetectorApp.install] Error 2
make[3]: Leaving directory `C:/Epics/support/areaDetector-2-4/ADExample/iocs/ADC
SimDetectorIOC'
make[2]: *** [ADCSimDetectorIOC.install] Error 2
make[2]: Leaving directory `C:/Epics/support/areaDetector-2-4/ADExample/iocs'
make[1]: *** [iocs.install] Error 2
make[1]: Leaving directory `C:/Epics/support/areaDetector-2-4/ADExample'
make: *** [C:\Epics\support\areaDetector-2-4/ADExample.install] Error 2
I then switched to staticlib for opencv. My config_site.local now looks like this:
OPENCV = C:/opencv-2.4.13
OPENCV_LIB = $(OPENCV)/build/x64/vc12/staticlib
OPENCV_INCLUDE = -I$(OPENCV)/build/include/
and the commonDriverMakefile:
ifdef ADPLUGINEDGE
ifdef OPENCV_LIB
PROD_LIBS += opencv_core2413 opencv_imgproc2413
else
PROD_SYS_LIBS += opencv_core2413 opencv_imgproc2413
endif
endif
In this case I still get a similar error as before.
make[6]: *** No rule to make target `../../../lib/windows-x64/opencv_core2413.li<http://opencv_core2413.li>
b', needed by `simDetectorNoIOCApp.exe'. Stop.
When you say building dynamic I assume you mean the opencv libs I am using are built dynamic, i build epics base as static.
Thanks
Ali
On Wed, Aug 3, 2016 at 3:04 PM, Mark Rivers <[email protected]<mailto:[email protected]>> wrote:
Because you are building dynamically you also need to define LIB_LIBS the same way you defined PROD_LIBS.
If this works you could make a pull request for the fix.
Sent from my iPhone
On Aug 3, 2016, at 2:06 PM, Alireza Panna <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>> wrote:
I am trying to use ADPluginEdge with the sim detector and I run into the following error:
make[6]: Entering directory `C:/Epics/support/areaDetector-2-4/ADExample/iocs/si
mDetectorNoIOC/simDetectorNoIOCApp/src/O.windows-x64'
cl /nologo /EHsc /GR -c /favor:blend /nologo /D__STDC__=0 /D_CRT_
SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 -DH5
_BUILT_AS_STATIC_LIB /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I.. -I.
.\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include -I..\\..\\..\\..\\..\\inclu
de -IC:\Epics\base-3.14.12.5\\include\\os\\WIN32 -IC:\Epics\base-3.14.12.5\\
include -IC:\Epics\support\\asyn-4-29\\include -IC:\Epics\support\areaDetector-
2-5\\ADBinaries\\include\\os\\WIN32 -IC:\Epics\support\areaDetector-2-4\\ADBinar
ies\\include -IC:\Epics\support\areaDetector-2-4\\ADCore\\include\\os\\WIN32 -IC
:\Epics\support\areaDetector-2-4\\ADCore\\include -IC:\Epics\support\\autosave-5
-7-1\\include\\os\\WIN32 -IC:\Epics\support\\autosave-5-7-1\\include -IC:\Epics
\support\\busy-1-6-1\\include -IC:\Epics\support\\calc-3-2\\include -IC:\Epics
\support\\seq-2-1-18\\include -IC:\Epics\support\\sscan-2-10-1\\include -IC:\Ep
ics\support\\devIocStats-3-1-14\\include\\os\\WIN32 -IC:\Epics\support\\devIocSt
ats-3-1-14\\include -IC:\Epics\support\\caPutLog-3-4\\include -I\\usr\\lo
cal64\\include -I\\usr\\include\\libxml2 ..\\simDetectorNoIOC.cpp
make[6]: *** No rule to make target `../../../lib/windows-x64/opencv_world310.li<http://opencv_world310.li><http://opencv_world310.li>
make[6]: Leaving directory `C:/Epics/support/areaDetector-2-4/ADExample/iocs/sim
make[5]: Leaving directory `C:/Epics/support/areaDetector-2-4/ADExample/iocs/sim
DetectorNoIOC/simDetectorNoIOCApp/src'
make[4]: Leaving directory `C:/Epics/support/areaDetector-2-4/ADExample/iocs/sim
DetectorNoIOC/simDetectorNoIOCApp'
make[3]: *** [simDetectorNoIOCApp.install] Error 2
make[3]: Leaving directory `C:/Epics/support/areaDetector-2-4/ADExample/iocs/sim
DetectorNoIOC'
make[2]: *** [simDetectorNoIOC.install] Error 2
To get it to compile and the plugin to work with the simDetector, I am manually copying the opencv_world310.lib file in the $(ADExample)/lib/$(EPICS_HOST_ARCH) directory.
my CONFIG_SITE.local has opencv location defined as:
OPENCV = C:/opencv-3.1
OPENCV_LIB = $(OPENCV)/build/x64/vc12/lib
and the commonDriverMakefile has the following defined:
ifdef ADPLUGINEDGE
ifdef OPENCV_LIB
PROD_LIBS += opencv_world310
else
PROD_SYS_LIBS += opencv_world310
endif
endif
Is there something else I need to add/change to get it to compile properly?
Thanks
Best,
Ali
- Re: compile error in ADExample/simDetector with opencv Alireza Panna
- compile error in ADExample/simDetector with opencv Alireza Panna
- Re: compile error in ADExample/simDetector with opencv Mark Rivers
EPICS support for SAES NEXTorr NEG & SIP Power Controllers Saraf, Shweta
<2016>
<2016>
