He said it was Ethernet, so it is not using Linux-GPIB, right?
From: [email protected] [[email protected]] on behalf of Rod Nussbaumer [[email protected]]
Sent: Thursday, July 28, 2016 12:20 PM
To: [email protected]
Subject: Re: may I start a pcaspy ioc together with a streamdevice ioc?
If this is using Linux-GPIB as the underlying asyn port driver, then
there is apparently a long standing bug that causes waveform records to
transfer very slowly with streamDevice. My workaround for this was to
use a waveform record with asynOctetCmdResponse DTYP (thanks to either
Eric or Mark for suggesting that) for that one operation. I post-process
the octet data using a subroutine record and it works fine. The OP's
problem seems to be a bit more complicated, as the array needs to be
sent, rather than received, but if the cause of the problem is a match,
at least the solution may be closer at hand.
Rod Nussbaumer,
TRIUMF,
Vancouver, Canada
On 07/25/2016 04:45 AM, Mark Rivers wrote:
> Why is StreamDevice slow to transfer the data? I don't think that should be the case, StreamDevice should be able to go as fast as any other software. I think the simplest solution would be to figure out why StreamDevice is slow for you.
> Mark
> From: [email protected] [[email protected]] on behalf of Silver [[email protected]]
> Sent: Monday, July 25, 2016 6:34 AM
> To: tech-talk
> Subject: may I start a pcaspy ioc together with a streamdevice ioc?
> hi, all
> I have a normal streamdevice ioc which controls power supply via ethernet. Now I want to add a function to send large waveform data (about 10000 floats) to power supply. If I just use streamdevice to transfer the data, the speed is slow and can't satisfy my requriement.
> I with to use pcaspy to creat another ioc as it can supply a pv to a client, for example, which inform to send data by a pv write, then the pcaspy ioc will send the data to power supply by ethernet. so I have two questions:
> 1. how to use the same socket of streamdevice? power supply controller has only one socket server. (during data transfer, I can stop the streamdevice db processing)
> 2. how to hook up the pcaspy ioc together with streamdevice ioc? (if I don't want to use procServ or inet, etc.)
> thanks a lot for your help.
> Best wishes
> Geyang 2016-07-25
- may I start a pcaspy ioc together with a streamdevice ioc? Silver
- RE: may I start a pcaspy ioc together with a streamdevice ioc? Mark Rivers
- Re: may I start a pcaspy ioc together with a streamdevice ioc? Rod Nussbaumer
RE: NDArrayPool::alloc failing Mark Rivers
<2016>
EPICS-Arduino Serial Communication via Asyn-Stream Drivers Hulusi Öz
<2016>
