I'm not sure I understand the question. If count is 0 then is there any point in allocating the NDArray and doing callbacks? Do you still want to pass NDAttributes to downstream plugins? If not, then why not just skip the NDArray allocation and callbacks when count is 0?
From: [email protected] [[email protected]] on behalf of Phil Atkin [[email protected]]
Sent: Monday, July 25, 2016 5:35 AM
To: [email protected]
Subject: areaDetector with 'empty' array output
My areaDetector plugin has an option to generate an array containing a 'list' of events. In pseudocode, it does something like the following in the processCallbacks method:
if (this->pArrays[0]) {
this->pArrays[0]->release();
this->pArrays[0] = NULL;
this->unlock();
// Copy the events list to the output array
size_t count = events.size();
dims[xDim] = count;
dims[yDim] = 3; // x, y and type
this->pArrays[0] = pNDArrayPool->alloc(2, dims, NDFloat32, 0, nullptr);
this->pArrays[0]->timeStamp = pArray->timeStamp;
this->pArrays[0]->epicsTS = pArray->epicsTS;
this->pArrays[0]->uniqueId = pArray->uniqueId;
pArray->pAttributeList->copy(this->pArrays[0]->pAttributeList);
this->lock();
// [Set some parameter values, including NDArraySizeX,Y,Z]
this->getAttributes(this->pArrays[0]->pAttributeList);
this->unlock();
doCallbacksGenericPointer(this->pArrays[0], NDArrayData, 0);
this->lock();
callParamCallbacks();
Currently I'm experiencing a crash if there are no events in the list. pNDArrayPool->alloc returns null if count is zero. I guess this is neither surprising nor unreasonable, but it leaves me with the question of what I should (and should not) do if the list is empty. I somehow need to 'output' something, otherwise plugins downstream won't be called, will they?
Thanks in advance,
Phil
[cid:[email protected]]Pixel Analytics is a limited company registered in England. Company number: 7747526; Registered office: 93A New Road, Haslingfield, Cambridge CB23 1LP
- Re: areaDetector with 'empty' array output Phil Atkin
- areaDetector with 'empty' array output Phil Atkin
RE: may I start a pcaspy ioc together with a streamdevice ioc? Mark Rivers
<2016>
<2016>
