1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Inconsistency in devAsynOctet for stringout and waveform records
To: Torsten Bögershausen <[email protected]>, "'Eric Norum'" <[email protected]>, Andrew Johnson <[email protected]>
Cc: "[email protected] list" <[email protected]>
Date: Sat, 23 Jul 2016 23:22:26 +0000
Sorry, I sent my previous reply too soon.
> For readIt(), the driver returns the length of the payload,
No, that is not true.  This is from asynPortDriver::readOctet
    *nActual = strlen(value)+1;
So it returns the length including the nil byte.
This change was made after tech-talk discussion in this thread:
http://www.aps.anl.gov/epics/tech-talk/2012/msg02251.php
The change was made in asyn R4-21, and is documented in the release notes:
“Changed the code so that the length of string parameters returned in
readOctet and octetCallback is now strlen(string)+1, rather than
strlen(string). The length thus now includes the terminating nil. This
fixes problems with clients that request long strings or subscribe to
monitors with a length of 0, but don't check for a nil terminator.”
> How many things would this change break ?
The problem is that currently an asyn port driver will see different behavior if it receives a string written with a stringout record compared to the same string written with a waveform record.  For a stringout record the length passed to the driver does not include the trailing nil, while for a waveform record is does include the trailing nil.  This is independent of whether the waveform record is written to with caput -S, or medm, or dbpf at the iocsh.
Since readIt does include the trailing nil, and since the waveform record does include the trailing nil on write, then I suggest that the correct fix is to include the trailing nil on write from the stringout record.
Sent: Saturday, July 23, 2016 5:34 PM
To: Mark Rivers; 'Eric Norum'; Andrew Johnson
Cc: [email protected] list
Subject: Re: Inconsistency in devAsynOctet for stringout and waveform records
How should the interface to the driver be ?
and asyn adds 1 for the terminating NUL before going out to the rest of
EPICS.
(Please correct me, if this is wrong)
For writeIt(), I would prefer to use the same principle,
and use the length of the payload, 3 in our case.
This would be in line with what the unix read() and write() functions do,
and, what I understand, the asyn-record does.
And, would need changes for the waveform record.
On 07/22/2016 10:55 PM, Mark Rivers wrote:
> Hi Eric and Andrew (and others),
> I have just found an inconsistency in the devAsynOctet.c for handling
> string output for stringout records versus waveform records.
> I have a stringout record which I process as follows:
> caput SIM1:SOHigh "abc"
> This is the output of devAsynOctet.c with some debugging statements added:
> devAsynOctet::callbackSoWrite, calling writeIt with message="abc",
> nbytes=3
> This is what happens when I write the same string with a waveform record:
> caput -S SIM1:WFOutHigh "abc"
> devAsynOctet::callbackWfWrite, calling writeIt with message="abc",
> nbytes=4
> So in the case of the stringout record the length being passed to the
> driver is strlen() of the string, while for the waveform record it is
> the NORD field of the waveform record.  NORD includes the terminating
> 0 byte.
> This difference in behavior is causing me problems when extending the
> Modbus driver to handle strings.
> Which do you feel is the “correct” behavior?  Should the driver be
> called with nbytes including the trailing 0 or not?
> You may recall that in asyn R4-21 we made the following change (from
> the release notes):
> So we do include the terminating nil in the length for readOctet.  For
> consistency it seems like the nil should be included in the length
> passed to the driver from writeOctet.  This means the stringout record
> support is the one that needs to be changed.
> Mark
Inconsistency in devAsynOctet for stringout and waveform records Mark Rivers
Re: Inconsistency in devAsynOctet for stringout and waveform records Torsten Bögershausen
RE: Inconsistency in devAsynOctet for stringout and waveform records Mark Rivers
Prev: Re: Inconsistency in devAsynOctet for stringout and waveform records Eric Norum
Next: RE: Inconsistency in devAsynOctet for stringout and waveform records Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Inconsistency in devAsynOctet for stringout and waveform records Mark Rivers
Next: Re: Inconsistency in devAsynOctet for stringout and waveform records Eric Norum
ANJ, 23 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
