1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: How to configurate MCA for Octave
To: Eric Norum <[email protected]>, [email protected]
Date: Fri, 22 Jul 2016 10:56:55 +0300
Sir, I am now in trouble about the iocshell commands. I am not able to run MCA commands (mcaget,mcaput etc.) in either iocshell or Octave.
Actually , I had this problem a few days ago while dealing with the Sequencer extension. I couldn't also do at that time
What I have done so far is :
I add the path in Octave like this ..
addpath("/opt/epics/extensions/lib/linux-x86_64")
addpath("/opt/epics/extensions/src/mca/matlab")
I tried to add registrar() into the dbd file. But, which dbd file should I add this to ? And which registrar() should I add to the dbd file ? I mean, a few years ago, according to do this message (http://www.aps.anl.gov/epics/tech-talk/2014/msg01886.php) I've done the steps.
As an extra question, let's say I could do all of these things and I could use the commands. Once I write a script in Octave, where should I save this file ? Should that saved in my_example that I'm running in the iocshell ? If it is that so, which direction should it be ?
Thanks in advance..Best regards..
Hulusi Öz
Re: How to configurate MCA for Octave Eric Norum
How to configurate MCA for Octave Hulusi Öz
Re: How to configurate MCA for Octave Hulusi Öz
Prev: RE: EpicsQT and Archiver Appliance Andrew C. Starritt
Next: Re: aravisGigE jumbo frame support Hinxx
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: How to configurate MCA for Octave Hulusi Öz
Next: Re: How to configurate MCA for Octave Eric Norum
ANJ, 22 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
