Thank you so much sir.. I built it successfully.. The things that i made wrong are : 1) I couldn't set up environment variables ,EPICS_EXTENSIONS,EPICS_BASE,EPICS_HOST_ARCH.. But,they're done.. 2) Once the enviironment variables are set up in the extension's folder,which is "/opt/epics/extensions/src/mca" for me, I run the "buildForOctave.sh" file at the same direction. But i had the same error.. 3) So I checked the octave shell path, I didn't install the "liboctave-dev" library . Then I installed it and made the same steps. In conclusion, all the things for building MCA for Octave worked fine.. All of things that I've done are thanks to you,sir.. Best Wishes for you.. Best Regards.. Hulusi 2016-07-21 20:34 GMT+03:00 Eric Norum <[email protected]>:
ANJ, 22 Jul 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
