1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: aravisGigE jumbo frame support
To: <[email protected]>, <[email protected]>
Date: Thu, 21 Jul 2016 08:57:25 +0000
That is a bit odd, I would have expected setting the packet size with the generic parameter set to work. I'm not sure if it needs to be done before the arvStream is created though. I haven't tested the driver with jumbo frames, but I did leave some commented out code in there that sets it up.
in aravisGigE/aravisGigEApp/src/araviscamera.cpp:
    391     // Make standard size packets
    392     arv_gv_device_set_packet_size(ARV_GV_DEVICE(this->device), ARV_GV_DEVICE_GVSP_PACKET_SIZE_DEFAULT);
    393     // Uncomment this line to set jumbo packets
    394 //    arv_gv_device_set_packet_size(ARV_GV_DEVICE(this->device), 9000);
Comment out line 392 and uncomment line 394 and see if that helps...
Tom Cobb
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Hinxx
> Sent: 21 July 2016 09:49
> To: EPICS Tech-Talk
> Subject: aravisGigE jumbo frame support
> Hi all,
> I'm trying to set MTU to 9000 (jumbo frames) when using Basler acA2000
> GigE camera with aravigGigE AD module in GIT.
> Under Linux I've set network MTU to 9000. Then I used the arv-tool-0.4
> tool to set the camera MTU to 9000.
> hinkokocevar@hinkocmbp:~$ arv-tool-0.4 control GevSCPSPacketSize
> Basler-21729661
> GevSCPSPacketSize = 1500 (min:220;max:16404)
> hinkokocevar@hinkocmbp:~$ arv-tool-0.4 control GevSCPSPacketSize=9000
> Basler-21729661
> GevSCPSPacketSize = 9000 (min:220;max:16404)
> Basler-21729661
> I can acquire images using arv-camera-test from the aravis package and
> the output suggests that MTU 9000 is respected:
> hinkokocevar@hinkocmbp:~$ arv-camera-test
> Looking for the first available camera
> (lt-arv-camera-test:13489): GLib-GIO-CRITICAL **:
> g_inet_address_new_from_string: assertion 'string != NULL' failed
> vendor name           = Basler
> model name            = acA2000-50gmNIR
> device id             = 21729661
> image width           = 2048
> image height          = 1080
> horizontal binning    = 1
> vertical binning      = 1
> payload               = 2211840 bytes
> exposure              = 0 µs
> gain                  = 36 dB
> gv n_stream channels  = 1
> gv current channel    = 0
> gv packet delay       = 0 ns
> gv packet size        = 9000 bytes
> Frame rate = 40 Hz
> Frame rate = 24 Hz
> Frame rate = 24 Hz
> Frame rate = 24 Hz
> Frame rate = 25 Hz
> Under aravisGigE I'm using generated feature OPI to access the
> 13ARV1:cam1:GevSCPSPacketSiz PV that initially holds 1500. Setting it to
> 9000 works, and I can confirm with arv-tool-0.4 at this point that
> camera is using MTU 9000.
> When stating the acquisition IOC console is flooded with messages:
> Bad frame status: 2 size: 2211840
> Any hints on what might be the problem?
> Thank you,
> Hinko
Re: aravisGigE jumbo frame support Hinxx
Prev: aravisGigE jumbo frame support Hinxx
Next: How to configurate MCA for Octave Hulusi Öz
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Next: Re: aravisGigE jumbo frame support Hinxx
ANJ, 21 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
