Hi all, I use synapp_5_8, seq-2-2-1, motor-6-9, Fedora 23,epics 3.15.3 I want to use the example in motor. So I change the Makefile in motor-6-9 as the motor-6-9/Makefile said. Then I "make clean uninstall" and "make". Error came. I noticed the http://www.aps.anl.gov/epics/tech-talk/2016/msg00379.php has met the same question, so I install the seq-2-2-3 as the web sadi. But it still has the error. The motor-6-9/Makefile is like these, *************** #Makefile at top of application tree # "#!" marks lines that can be uncommented. TOP = . include $(TOP)/configure/CONFIG DIRS += configure motorApp motorApp_DEPEND_DIRS = configure # To build motor examples; # 1st - uncomment lines below. # 2nd - uncomment required support module lines at the bottom of # <motor>/configure/RELEASE. # 3rd - make clean uninstall # 4th - make DIRS += motorExApp iocBoot motorExApp_DEPEND_DIRS = motorApp iocBoot_DEPEND_DIRS = motorExApp include $(TOP)/configure/RULES_TOP ************************************* I changed the /motor-6-9/Makefile, then when I make ,the error came out. This is part of output of make( the whole is too much ): ************************************** make[3]: Entering directory '/opt/epics/synApps_5_8/support/motor-6-9/motorExApp/WithAsyn/O.linux-x86_64' /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/opt/epics/synApps_5_8/support/asyn-4-26/include -I/opt/epics/synApps_5_8/support/seq-2-2-3/include -I/opt/epics/synApps_5_8/support/busy-1-6-1/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include -I/opt/epics/synApps_5_8/support/ipac-2-13/include -MM -MF WithAsynMain.d ../WithAsynMain.c Creating dbd file WithAsyn.dbd perl -CSD /opt/epics/base/bin/linux-x86_64/dbdExpand.pl -I. -I.. -I../O.Common -I../../../dbd -I/opt/epics/synApps_5_8/support/asyn-4-26/dbd -I/opt/epics/synApps_5_8/support/seq-2-2-3/dbd -I/opt/epics/synApps_5_8/support/busy-1-6-1/dbd -I/opt/epics/base/dbd -I/opt/epics/synApps_5_8/support/ipac-2-13/dbd -o WithAsyn.dbd base.dbd motorSupport.dbd devAcsMotor.dbd devImsMotor.dbd devMclennanMotor.dbd devMicos.dbd devMicroMo.dbd devNewport.dbd LdevNewportTS.dbd devPIMotor.dbd devOms.dbd devSoftMotor.dbd motorSimSupport.dbd devSmartMotorMotor.dbd devKohzuMotor.dbd devAttocube.dbd devAerotech.dbd ACRMotorSupport.dbd asyn.dbd drvAsynSerialPort.dbd drvAsynIPPort.dbd busySupport.dbd PI_GCS2Support.dbd phytron.dbd devSequencer.dbd dbdExpand.pl: Duplicate definition of record type '' Context: recordtype(asyn) in file '/opt/epics/synApps_5_8/support/asyn-4-26/dbd/asynRecord.dbd' in file '/opt/epics/synApps_5_8/support/asyn-4-26/dbd/asyn.dbd' in file '../../../dbd/PI_GCS2Support.dbd' while reading 'PI_GCS2Support.dbd' to create 'WithAsyn.dbd' dbdExpand.pl: Can't find file 'devSequencer.dbd' while reading 'devSequencer.dbd' to create 'WithAsyn.dbd' Your Makefile may need this dependency rule: $(COMMON_DIR)/WithAsyn.dbd: $(COMMON_DIR)/devSequencer.dbd dbdExpand.pl: Exiting due to errors /opt/epics/base/configure/RULES.Db:402: recipe for target '../O.Common/WithAsyn.dbd' failed make[3]: *** [../O.Common/WithAsyn.dbd] Error 2 make[3]: Leaving directory '/opt/epics/synApps_5_8/support/motor-6-9/motorExApp/WithAsyn/O.linux-x86_64' /opt/epics/base/configure/RULES_ARCHS:61: recipe for target 'install.linux-x86_64' failed make[2]: *** [install.linux-x86_64] Error 2 make[2]: Leaving directory '/opt/epics/synApps_5_8/support/motor-6-9/motorExApp/WithAsyn' /opt/epics/base/configure/RULES_DIRS:88: recipe for target 'WithAsyn.install' failed make[1]: *** [WithAsyn.install] Error 2 make[1]: Leaving directory '/opt/epics/synApps_5_8/support/motor-6-9/motorExApp' /opt/epics/base/configure/RULES_DIRS:88: recipe for target 'motorExApp.install' failed make: *** [motorExApp.install] Error 2 Thank you. Li xing
ANJ, 19 Jul 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
