Hi Steve,
On 07/08/2016 08:40 AM, Stephen Molloy wrote:
>>> $user= $opt_u|| $ENV{USER}|| $ENV{USERNAME}|| Win32::LoginName();
>> I agree that doesn't look terribly robust, but for a Linux environment
>> to not define $USER seems rather unusual. Does this one-liner output the
>> username correctly?
>> perl -e 'printf "%s\n", getlogin();’
> That also results in a blank.
Ok, I guess we don't have to get a definitive answer from the OS in this
case given the code that follows the above line, as long as that prompt
gets triggered.
Does making this change result in you being prompted for a user-name?
> === modified file 'src/makeBaseApp/makeBaseApp.pl'
> --- src/makeBaseApp/makeBaseApp.pl 2016-05-22 03:43:09 +0000
> +++ src/makeBaseApp/makeBaseApp.pl 2016-07-08 15:44:43 +0000
> @@ -418,7 +418,8 @@
> sub GetUser {
> - $user = $opt_u || $ENV{USER} || $ENV{USERNAME} || Win32::LoginName();
> + $user = $opt_u || $ENV{USER} || $ENV{USERNAME} || getlogin();
> + $user = Win32::LoginName() if !$user && $^ eq 'MSWin32';
> unless ($user) {
> print "Strange, I cannot figure out your user name!\n";
If not I'll ask you work out how to fix this and send us your suggested
patch instead.
> To be honest, I don’t think that this would be the best way of using
> Docker for this task, but I thought that it was worth reporting
> something that looked like a bit of a weakness in makeBaseApp.
Thanks, every little helps!
- Andrew
- Re: Unreachable code in makeBaseApp.pl? Stephen Molloy
Re: Unreachable code in makeBaseApp.pl? Ralph Lange
<2016>
<2016>
