Hi Steve,
A CA client uses ephemeral ports as originating port numbers, correct.
Ephemeral port numbers are indeed random, and cannot be predicted reliably.
However, if your container contains an IOC (CA server), opening ports
5064&5065 (in the default setup) for both TCP and UDP should allow any
client outside the container to connect. (Not much different to a
container with a web service published at port 80.)
The CA client in the container would still use ephemeral port numbers
for outgoing connections - do you need to publish those?
Cheers,
~Ralph
On 04/07/2016 16:43, Stephen Molloy wrote:
I’m trying to build a Docker container for quick set-up and tear-down
of EPICS instances, and I’ve run into a problem. A CA client outside
the container, but on the same host, cannot see any PV’s served from
inside the container.
Looking at the network traffic with Wireshark, I can see that the
server uses ports 5064 & 5065 as expected, but the ports used by the
client seem to be relatively random. If I could predict them, or
(even better) force them to be specific ports, then I could expose
those ports in the Docker container and (hopefully) the client and
server could communicate properly.
Or perhaps this isn’t the problem, and there is some other network
issue getting in my way.
(I’ve successfully run several EPICS installations on this network and
from this computer, so I am confident that this is an issue with the
Docker set-up.)
Hopefully I’m on the right track with my thinking, and hopefully
someone can let me know how to proceed from here?
In case you’re interested, I’m documenting my work on my blog —
http://www.smolloy.com/2016/07/easy-epics-implementation-with-docker/
Thanks (again) for your time,
Steve
- Re: Post numbers used by CA client Stephen Molloy
- Post numbers used by CA client Stephen Molloy
Re: gddAppFuncTableStatus string Michael Westfall
<2016>
<2016>
ANJ, 15 Jul 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
