OK, here's how it should work:
On the IOC side I have a file test.db that only contains a
minimal ai record:
record(ai,"foo") { }
and I am running this in a 3.15 'softIoc -d test.db'.
On the client side I am running camonitor in the background, and
then do 'caput's to see if I get updates.
First test: without setting the mask to DBE_PROPERTY, changing
the units should not send monitor updates.
~ $ camonitor foo &
[1] 11517
~ $ foo
<undefined> 0 UDF INVALID
~ $ caput foo.EGU V
Old : foo.EGU
New : foo.EGU V
~ $ caput foo.EGU A
Old : foo.EGU V
New : foo.EGU A
Second test: setting the event mask to DBE_PROPERTY, changing the
units should send monitor updates.
~ $ camonitor -m p foo &
[1] 11718
~ $ foo
~ $ caput foo.EGU V
Old : foo.EGU
New : foo.EGU V
foo
~ $ caput foo.EGU A
Old : foo.EGU V
New : foo.EGU A
foo
This is the expected and correct behavior.
You are missing that, as I wrote in my mail of June 07 (see below),
the event type flag DBE_PROPERTY was introduced in EPICS 3.14.11,
but proper support for the EPICS records is only available in the
EPICS 3.15 series.
Applied to your case, this means that to get updates for changes to
the EGU field, the IOC has to use Base 3.15 (like my example above).
Cheers,
~Ralph
On 04/07/2016 08:45, Shantonu Sahoo
wrote:
Thanks for the support.
But I am stuck at the first step that
you suggested. I could not get the property change updates
using 'camonitor -m p' on the command line when I change the
units.
I am
using EPICS base 3.14.12.5. I guess DBE_PROPERTY was
introduced in 3.14.11, so it should work with 3.14.12.5. Am
I missing out something?
Shantonu
Sahoo
वैज्ञानिक
अधिकारी / Scientific Officer
कंप्यूटर
एवं सूचना वर्ग / Computer and Informatics Group
परिवर्ती
ऊर्जा साइक्लोट्रॉन केन्द्र / Variable Energy Cyclotron
Center
Ph: (033)
23182300
[email protected]
wrote: -----
To: EPICS Tech-Talk
<[email protected]>
Sent by: [email protected]
Date: 06/07/2016 10:21PM
Subject: Re: Problem in updating EGU field in CSS-BOY
Hello:
The support for DBE_PROPERTY has been added to
CS-Studio some time ago, but that was at a time when
the Channel Access gateway didn't support it, and on
the IOC side basically only the 'enumeration' labels
of respective record types (bi, bo, mbbi, mbbo) sent
out DBE_PROPERTY updates.
What's happening is that the CA client creates two
subscriptions: One for value updates, and one for
property updates. If you have older IOCs or CA
gateways, they won't understand the second
subscription, so the client gets one error per channel
from those refused subscriptions.
The DBE_PROPERTY feature has thus not been used a lot,
and I must admit I've basically forgotten about it
since we can't universally use it in our local setup
(older IOCs, ..).
Still, fundamentally the support should be there.
Check with 'camonitor' on the command line, using the
"-m p" option to monitor property changes, so assert
that your record indeed sends updates when you change
the units.
Then use a recent version of CSS, something with 4.2.x
as a version number.
Its "diirt PVManager" is unfortunately configured via
files outside of CSS.
In Edit/Preferences, look for CSS Core, Diirt
preferences. You specify a Diirt configuration
directory that needs to contain files like the ones
found here:
https://github.com/ControlSystemStudio/org.csstudio.sns/tree/master/features/org.csstudio.sns.feature.snscore/rootfiles/diirt
Note the file datasources/ca/ca.xml, it contains a
setting `dbePropertySupported` that defaults to false.
You need to set that to 'true'.
Now tools that use the "diirt PVManager" should
receive monitors for property changes. This includes
BOY as long as you have the Edit, Preferences, CSS
Applications, Display, BOY, OPI Runtime setting for
"PV Connection layer" set to "pvmanager".
If it doesn't work, we should create an issue ticket
on https://github.com/ControlSystemStudio/cs-studio/issues to
continue the discussion there.
Kay
<[email protected]> on behalf of
Ralph Lange <[email protected]>
Sent: Tuesday, June 07, 2016 8:04 AM
To: EPICS Tech-Talk
Dear Shantonu,
The new Channel Access event type flag DBE_PROPERTY
was introduced in EPICS 3.14.11, but proper support
for the EPICS records is only available in the EPICS
3.15 series.
I do not have a good idea about how CS-Studio, BOY and
CAJ are supporting this feature. I was prompting you
for the versions, hoping that one of the CS-Studio
people would pick your question up. (With the version
numbers, they should be able to give an answer.)
Sorry...
~Ralph
On 07/06/2016 13:23, Shantonu Sahoo wrote:
Dear Ralph,
Can you tell me the exact versions of EPICS base, CSS
and CAJ in which this feature is incorporated.
Shantonu Sahoo
वैज्ञानिक अधिकारी / Scientific Officer
कंप्यूटर एवं सूचना वर्ग / Computer and Informatics
Group
परिवर्ती ऊर्जा साइक्लोट्रॉन केन्द्र / Variable Energy
Cyclotron Center
Ph: (033) 23182300
[email protected] wrote: -----
To: Ralph Lange <[email protected]>
Date: 06/06/2016 03:27PM
Cc: EPICS Tech-Talk <[email protected]>
I am using EPICS base-3.14.12.5, CS-Studio 4.1.4 ,
Java Utilities 3.2.0. I am not sure about the version
of CAJ. I am not using EPICS CA Gateway.
Shantonu Sahoo
Group
Cyclotron Center
Ph: (033) 23182300
-----Ralph Lange <[email protected]> wrote:
To: EPICS Tech-Talk <[email protected]>
Date: 06/06/2016 02:19PM
Cc: Shantonu Sahoo <[email protected]>
A feature to allow such updates of metadata has been
added to EPICS Base and the Channel Access protocol
recently.
What versions of EPICS Base (your IOC), CS-Studio
(your client) and CAJ (the Java CA client library
inside CS-Studio) are you using? Is there an EPICS CA
Gateway involved? (If yes, what version?)
~Ralph
On 06/06/2016 10:29, Shantonu Sahoo wrote:
I am using CSS-BOY to display a process variable using
"Text Update". I have checked the "Show Units"
property. So, in addition to the VALue, it displays
the string that is specified in the EGU field of the
record. But, in the runtime, if the EGU field
changes, it is not updated in the OPI until I do
"Refresh OPI". In contrary, the VALue is updated
smoothly.
Shantonu Sahoo
Group
Cyclotron Center
Ph: (033) 23182300
