1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Including libraries in subroutines
Date: Tue, 28 Jun 2016 18:42:50 +0000
I just wanted to confirm that Andrew’s recommendation to use PROD_SYS_LIBS in the appropriate Makefile did the trick.
Many thanks for the very fast response.
Steve
Date: Tuesday 28 June 2016 at 00:27
Thanks Andrew.
libwiringPi.so can be found in /usr/lib on my system, so I will try your suggested PROD_SYS_LIBS solution.
(But tomorrow — it’s late in Sweden now…)
Steve
Date: Monday 27 June 2016 at 23:53
Subject: Including libraries in subroutines
Let me apologise in advance for a very basic question.
I have some C code that I would like to convert to a subroutine record.  I normally build the executable with g++ using a  -lwiringPi flag, but I don’t know the correct way to do this in order to compile the EPICS subroutine.  Is there a standard place I should put the library, or is there some change I need to make to the Makefile (and, if so, which Makefile?) to get this to work?
Steve
Including libraries in subroutines Stephen Molloy
Re: Including libraries in subroutines Stephen Molloy
Prev: RE: Compiling EPICS 3.14.12.5 with GCC 6 Hill, Jeff
Next: Re: IOCs under procServ as system services under systemd? Konrad, Martin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Including libraries in subroutines Stephen Molloy
Next: Compiling EPICS 3.14.12.5 with GCC 6 Luca Cavalli
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
