1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: IOCs under procServ as system services under systemd?
To: EPICS Tech-Talk <[email protected]>
Date: Mon, 27 Jun 2016 14:38:29 +0000
Hi all,
Niklas and Stefani, thanks for sharing your systemd unit configuration.
It came just at the right time :-) I put together a similar one. Using
the foreground option (-f) of procServ is the recommended way with
systemd. My unit configuration [1] differs in some details:
> ConditionFileIsExecutable=/usr/bin/procServ
> ConditionFileIsExecutable=/usr/local/ops/iocBoot/ioccontrol/st.cmd
This causes systemd to silently skip the service if one of these files
is not executable. Stefani, are you sure that's the behavior you want? I
would prefer it to fail with an error message instead (remove these two
lines).
I'm using "Restart=always" to make sure procServ is restarted
automatically even if it exited cleanly. I don't want users to find out
that they are not able to restart procServ after they shut it down by
pressing Ctrl-Q.
Note how systemd makes our life as developers easier: Daemons don't need to
- fork
- write PID files
- drop privileges by themselves
Systemd takes care of all these things for us :-)
Cheers,
Martin
[1]
https://stash.nscl.msu.edu/projects/DEPLOY/repos/puppet_module_epics_softioc/browse/templates/etc/systemd/system/ioc.service
Martin Konrad
Control System Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
Re: IOCs under procServ as system services under systemd? Andrew Johnson
IOCs under procServ as system services under systemd? Ralph Lange
Re: IOCs under procServ as system services under systemd? Niklas Claesson
Prev: Re: question of data conversion Remi Faure
Next: Re: IOCs under procServ as system services under systemd? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: IOCs under procServ as system services under systemd? S. Banerian
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
