I have tried to add “configure” but got stuck when it seemed that for
each EPICS release, the configure is a bit different. A configure
created with 3.14.12 did not work with 3.14.8 for me. Maybe if I find
some time, I will try again.
Dirk
On 23.06.2016 19:12, Andrew Johnson wrote:
Dirk,
On 06/22/2016 04:45 PM, Hu, Yong wrote:
@Dirk, why do not you include “configure” in your official StreamDevice
release?
I am considering switching the StreamDevice links on the EPICS website
to point to the synApps github repo, since your releases have been an
unfortunate cause of confusion and time-wasting for many new EPICS users
like Peter and Yong.
I understand that the module is designed to be able to build on both
Base-3.14 and Base-3.13, but I suspect that only PSI uses StreamDevice
on Base-3.13. The rest of the community would much prefer to download a
standard 3.14 module, edit the configure/RELEASE file and run 'make'.
Since you now use git which supports submodules, would you consider
using something like that to make releases that build under Base-3.14
and higher right out of the box?
- Andrew
- RE: streams drivers Mark Rivers
- Re: streams drivers Peter Blanco
- Re: streams drivers Hu, Yong
- Re: streams drivers Andrew Johnson
EPICS connect to siemens PLC317-2PN/DP: connetction problem XU Jie
question of data conversion Remi Faure
<2016>
ETHERCAT-4-3 on linux-arm yann
<2016>
