Hi,sir:
I have solved the problem about Illegal field value PV, but still cann't connetc the IOCsoft used the driver package s7plc.tgz from PSI to siemens PLC317-2PN/DP. Because I havn't the CP module such as CP343-1 and so on, I'm trying to use CPU integrated ProfiNet interface to achieve TCP communication between the IOCsoft and siemens PLC317-2PN/DP, but it has always problems. How to configure PLC without CP module?
Thank you.
Look forward to your answer.
Best regards,
Jie Xu
The detail like the following:
#!../../bin/linux-x86_64/firstIoc
#< envPaths
dbLoadDatabase("../../dbd/firstIoc.dbd",0,0)
firstIoc_registerRecordDeviceDriver(pdbbase)
var s7plcDebug 1
s7plcConfigure Testsystem:0,192.168.10.152,2000,10,10,1,2000,500
## Load record instances
dbLoadRecords("../../db/example.db","user=root")
iocInit()
Starting iocInit
## EPICS R3.16.0.1 $Date: Thu 2016-03-03 17:36:43 -0600$
## EPICS Base built Jun 24 2016
s7plcInit: starting main thread
s7plcMain: main thread started
s7plcIoParse s7-status: station=Testsystem:0
s7plcIoParse s7-status: offs=0
s7plcIoParse s7-status: dlen=2
s7plcIoParse s7-status: B=0
s7plcIoParse s7-status: L=0xffff8001
s7plcIoParse s7-status: H=0x7fff
s7plcIoParse ai-int16-1: station=Testsystem:0
s7plcIoParse ai-int16-1: offs=0
s7plcIoParse ai-int16-1: dlen=2
s7plcIoParse ai-int16-1: B=0
s7plcIoParse ai-int16-1: L=0
s7plcIoParse ai-int16-1: H=0x3e8
s7plcMain Testsystem:0: Connect to 192.168.10.152:2000 on socket 5
s7plcEstablishConnection Testsystem:0: fd=5, IP=192.168.10.152 port=2000
s7plcEstablishConnection Testsystem:0: background connect(5,...) failed: Connection refused
s7plcMain Testsystem:0: connect(5, 192.168.10.152:2000) failed: Connection refused. Retry in 10 seconds
s7plcMain Testsystem:0: starting send thread Testsystem:0S
s7plcMain Testsystem:0: starting recv thread Testsystem:0R
s7plcSendThread Testsystem:0: started
s7plcReceiveThread Testsystem:0: started
cas warning: Configured TCP port was unavailable.
cas warning: Using dynamically assigned TCP port 40392,
cas warning: but now two or more servers share the same UDP port.
cas warning: Depending on your IP kernel this server may not be
cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
## Start any sequence programs
#seq sncfirstIoc,"user=root"
epics> s7plcMain Testsystem:0: Connect to 192.168.10.152:2000 on socket 8
s7plcEstablishConnection Testsystem:0: fd=8, IP=192.168.10.152 port=2000
s7plcEstablishConnection Testsystem:0: background connect(8,...) failed: Connection refused
s7plcMain Testsystem:0: connect(8, 192.168.10.152:2000) failed: Connection refused. Retry in 10 seconds
s7plcReceiveThread Testsystem:0: recv(-1, ..., 10, 0) failed: Bad file descriptor
record (bi, "s7-status")
field (DTYP, "S7plc stat")
field (INP, "@Testsystem:0")
field (SCAN, "I/O Intr")
field (ZNAM, "disconnected")
field (ONAM, "connected")
field (ZSV, "MAJOR")
field (FLNK, "s7-status-counter")
record (calc, "s7-status-counter")
field (INPA, "s7-status-counter")
field (CALC, "A+1")
field (FLNK, "s7-disconnect-counter")
record (calc, "s7-disconnect-counter")
field (INPA, "s7-status")
field (INPB, "s7-disconnect-counter.LA")
field (INPC, "s7-disconnect-counter")
field (CALC, "(A=0&&B=1)?C+1:C")
record (ai, "ai-int16-1")
field (DTYP, "S7plc")
field (INP, "@Testsystem:0/0 T=INT16 L=0 H=1000")
field (EGUF, "10")
field (LOPR, "-10")
field (HOPR, "10")
field (LINR, "LINEAR")
field (PREC, "2")
-----原始邮件-----
发件人: "XU Jie" <[email protected]>
发送时间: 2016-06-23 12:09:20 (星期四)
收件人: [email protected], [email protected]
抄送:
主题: re:Re: EPICS connect to PLC:Illegal field value PV ;Connection timed
Hi,sir:
Thank you for your help, but it still doesn't work and show the problem that: Illegal field value PV .
Thank you.
Best regards,
Jie Xu
Subject: Re: EPICS connect to PLC:Illegal field value PV ;Connection timed
To: "[email protected]" <[email protected]>
Date: Mon, 20 Jun 2016 09:35:16 +0000
"Illegal field value PV: ai-int16-1 s7plcInitRecordAi: illegal INP field type"
Judging by this, your EPICS isn't happy about "INP" field.
This is what you have now:
field (INP, "@Testsystem:0/0 'T=INT16 L=0 H=1000'")
Looking through this (http://epics.web.psi.ch/style/software/s7plc/s7plc.html) the obvious first thing to try would be to remove extra pair of single quotation marks that you have.
Change
to
See if this helps?
______________________
Nick Levchenko
Control Systems Engineer
Integrated Control System Division
European Spallation Source ERIC
P.O Box 176, SE-221 00 Lund, Sweden
Visiting address: Tunavägen 24, Lund
Mobile: +46 721 79 23 64
Phone: +46 46 888 33 64
E-mail: [email protected]
www.esss.se
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of [email protected]
Sent: 18 June 2016 19:00
To: [email protected]
Subject: Tech-talk Digest, Vol 10, Issue 239
Send Tech-talk mailing list submissions to
[email protected]
To subscribe or unsubscribe via the World Wide Web, visit
https://mailman.aps.anl.gov/mailman/listinfo/tech-talk
or, via email, send a message with subject or body 'help' to
[email protected]
You can reach the person managing the list at
[email protected]
When replying, please edit your Subject line so it is more specific than "Re: Contents of Tech-talk digest..."
Today's Topics:
1. EPICS connect to PLC:Illegal field value PV ;Connection timed
out (XU Jie)
Message: 1
Date: Sat, 18 Jun 2016 16:12:24 +0800 (GMT+08:00)
Subject: EPICS connect to PLC:Illegal field value PV ;Connection timed
out
Message-ID: <[email protected]>
Content-Type: text/plain; charset=UTF-8
Hello sir,
I used the driver package s7plc.tgz from PSI and tried to connetct the EPICS IOCsoft and siemens PLC317-2PN/DP with TCP protocol. When the IOC starts, the problems like these followed:
Illegal field value PV: ai-int16-1 s7plcGetInIntInfo: uninitialized record
s7plcReceiveThread Testsystem:0: read error after 0 of 10 bytes: Connection timed out
Is the cause of the problems the ioc failed to connect with PLC? Or there are other reasons?
Thank you.
Best regards,
Jie Xu
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","iocfirstIocboot")
epicsEnvSet("TOP","/home/newuser/EPICS/base-3.16.0.1/support")
epicsEnvSet("EPICS_BASE","/home/newuser/EPICS/base-3.16.0.1")
cd "/home/newuser/EPICS/base-3.16.0.1/support"
dbLoadDatabase "dbd/firstIoc.dbd"
firstIoc_registerRecordDeviceDriver pdbbase var s7plcDebug 1
s7plcConfigure Testsystem:0,192.168.10.152,102,10,10,1,2000,500
dbLoadRecords db/first.db
iocInit
Starting iocInit
## EPICS R3.16.0.1 $Date: Thu 2016-03-03 17:36:43 -0600$ ## EPICS Base built Jun 7 2016 ############################################################################
s7plcMain Testsystem:0: Connect to 192.168.10.152:102 on socket 5 s7plcEstablishConnection Testsystem:0: fd=5, IP=192.168.10.152 port=102 Illegal field value PV: ai-int16-1 s7plcInitRecordAi: illegal INP field type
s7plcMain Testsystem:0: starting send thread Testsystem:0S s7plcMain Testsystem:0: starting recv thread Testsystem:0R s7plcSendThread Testsystem:0: started s7plcReceiveThread Testsystem:0: started
#seq sncxxx,"user=newuser"
epics> s7plcWaitForInput Testsystem:0: select(5, 2.000000 sec) timed out
first.db
record (ai, "ai-int16-1") {
# map range 0 ... 1000 to 0.0000 ... 10.0000
field (EGUF, "10")
field (LOPR, "-10")
field (HOPR, "10")
field (PREC, "2")
Tech-talk mailing list [email protected] https://mailman.aps.anl.gov/mailman/listinfo/tech-talk
End of Tech-talk Digest, Vol 10, Issue 239
- RE: EPICS connect to siemens PLC317-2PN/DP: connetction problem Esmaeil Tabar
RE: FAREX SR Mini HG System ? Heesterman, Peter J
Re: streams drivers Dirk Zimoch
<2016>
<2016>
