Mark's suggestion : Doing a git clone of the repository & rebuilding everything did it.
Thanks for your input
Peter Blanco
Test/Software Eng. Kepco Inc.
Ralph Lange < [email protected]>
To:
Peter Blanco < [email protected]>
Cc:
EPICS Tech-Talk < [email protected]>
Sent:
6/22/2016 9:05 AM
Subject:
Re: streams drivers
Hi Peter,
Can you show how your records' links look like, and the StreamDevice
protocol you are using?
NB: You should not compile StreamDevice inside EPICS Base. But
that's not necessarily connected to the issues you see.
Cheers,
~Ralph
On 22/06/2016 14:49, Peter Blanco
wrote:
Hello,
I'm trying to use the “Glassman”
Power Supply driver which uses streams, also tried a couple
other
streams drivers & also went through the tutorial steps to
build
one from scratch, all have same problem.
Below is a screen printout that I
got
when running the "Glassman" driver TestApp .
I believe the problem may be with
the
StreamDevice itself.
The only place I could build StreamDevice
without getting errors was EPICS/base, otherwise it would
complain
about not finding stuff.
- Re: streams drivers Ralph Lange
Re: streams drivers Peter Blanco
FAREX SR Mini HG System ? Heesterman, Peter J
<2016>
RE: streams drivers Mark Rivers
<2016>
ANJ, 15 Jul 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
