trying to build StreamDevice in /home/blanco/Desktop/EPICS/support/StreamDevice
In release : by default TOP = ..
but that gives me :
blanco@kepcoubuntu-Precision-WorkStation-490:~/Desktop/EPICS/support/StreamDevice$ make
Makefile:10: ../config/CONFIG_APP: No such file or directory
Makefile:25: ../config/RULES_DIRS: No such file or directory
make: *** No rule to make target '../config/RULES_DIRS'. Stop.
tried changing TOP to many different things i.e. /home/blanco/Desktop/EPICS/base that gives me:
make -C ./src install
make[1]: Entering directory '/home/blanco/Desktop/EPICS/support/StreamDevice/src'
Makefile:26: ../../config/CONFIG_APP: No such file or directory
Makefile:28: ../../config/RULES_ARCHS: No such file or directory
make[1]: *** No rule to make target '../../config/RULES_ARCHS'. Stop.
make[1]: Leaving directory '/home/blanco/Desktop/EPICS/support/StreamDevice/src'
/home/blanco/Desktop/EPICS/base/configure/RULES_DIRS:87: recipe for target 'src.install' failed make: *** [src.install] Error 2
The confusion is where to put StreamDevice directory. As I said if I put StreamDevice dir in /home/blanco/Desktop/EPICS/base , the build works, else it can't find things.
Peter Blanco
Test/Software Eng. Kepco Inc.
Mark Rivers < [email protected]>
To:
Peter Blanco < [email protected]>, " [email protected]" < [email protected]>
Sent:
6/22/2016 1:13 PM
Subject:
RE: streams drivers
I think it would be good for you to move StreamDevice from EPICS/base to EPICS/support. You said that did not work, but it should. Perhaps that will show us the source of the problem. Send us the StreamDevice build output when you do that.
________________________________________ From: [email protected] [[email protected]] on behalf of Mark Rivers [[email protected]] Sent: Wednesday, June 22, 2016 12:06 PM To: Peter Blanco; [email protected] Subject: RE: streams drivers
OK, so your problem is starting with this line in your build output:
perl ../makeref.pl Interface Debug Dummy > streamReferences
This is what I get when I build 2.6
perl ../makeref.pl Interface Debug Dummy AsynDriver > streamReferences
It is also not compiling AsynDriverInterface.cc.
This really seems like it is a problem with the definition of ASYN in configure/RELEASE. Are you sure that there is no typo there?
________________________________ From: Peter Blanco [[email protected]] Sent: Wednesday, June 22, 2016 11:34 AM To: Mark Rivers; [email protected] Subject: Re: streams drivers
I rebuilt 2.6, same problem. attaced is the output
Peter Blanco Test/Software Eng. Kepco Inc.
From: Mark Rivers <[email protected]> To: Peter Blanco <[email protected]>, "[email protected]" <[email protected]> Sent: 6/22/2016 11:54 AM Subject: RE: streams drivers
Yes, dbior is getting reports both from StreamDevice and from asynManager. That is normal. But the problem is that StreamDevice is not listing the asyn bus interface.
Can you send the complete output when you rebuild StreamDevice 2.7.6?
________________________________ From: Peter Blanco [[email protected]] Sent: Wednesday, June 22, 2016 10:46 AM To: Mark Rivers; [email protected] Subject: Re: streams drivers
I agree. Actually I get 2 drivers listed separately : epics> dbior Driver: stream StreamDevice 2.7.6 built Jun 21 2016 10:23:43 registered bus interfaces: DebugInterface DummyInterface Driver: drvAsyn L0 multiDevice:No canBlock:Yes autoConnect:Yes epics>
According to the doc: # asynDriver interface is added automatically # if ASYN is defined in your RELEASE file.
I will try to use the 2.6 version, though I may have already done that. Might it also be an issue with Ubuntu ?
From: Mark Rivers <[email protected]> To: Peter Blanco <[email protected]>, "[email protected]" <[email protected]> Sent: 6/22/2016 10:01 AM Subject: RE: streams drivers
Your problem can be seen in the output of the dbior command. This is what I get
Driver: stream StreamDevice 2.6.0 built May 11 2016 15:20:49 registered bus interfaces: DebugInterface DummyInterface AsynDriverInterface
This is what you get:
Note that you are missing AsynDriverInterface. That is the problem. Now the question is why?
I see you are using a more recent version of StreamDevice than I am. Perhaps there is something you need to set when you build StreamDevice now to enable the asyn bus interface?
________________________________ From: Peter Blanco [[email protected]] Sent: Wednesday, June 22, 2016 8:37 AM To: Mark Rivers; [email protected] Subject: Re: streams drivers
here it is :
blanco@kepcoubuntu-Precision-WorkStation-490:~/Desktop/EPICS/DEBUG/Glassman$ grep -i stream dbd/Glassman.dbd device(aai,INST_IO,devaaiStream,"stream") device(aao,INST_IO,devaaoStream,"stream") device(ai,INST_IO,devaiStream,"stream") device(ao,INST_IO,devaoStream,"stream") device(bi,INST_IO,devbiStream,"stream") device(bo,INST_IO,devboStream,"stream") device(calcout,INST_IO,devcalcoutStream,"stream") device(longin,INST_IO,devlonginStream,"stream") device(longout,INST_IO,devlongoutStream,"stream") device(mbbi,INST_IO,devmbbiStream,"stream") device(mbbiDirect,INST_IO,devmbbiDirectStream,"stream") device(mbbo,INST_IO,devmbboStream,"stream") device(mbboDirect,INST_IO,devmbboDirectStream,"stream") device(stringin,INST_IO,devstringinStream,"stream") device(stringout,INST_IO,devstringoutStream,"stream") device(waveform,INST_IO,devwaveformStream,"stream") driver(stream) registrar(streamRegistrar) variable(streamDebug,int) blanco@kepcoubuntu-Precision-WorkStation-490:~/Desktop/EPICS/DEBUG/Glassman$
From: Mark Rivers <[email protected]> To: Peter Blanco <[email protected]>, "[email protected]" <[email protected]> Sent: 6/22/2016 9:24 AM Subject: RE: streams drivers
That looks OK. Perhaps the problem is your application dbd file.
Send the output of
I get the following for my application:
corvette:~/devel/CARS/dbd>grep -i stream CARSLinux.dbd device(aai,INST_IO,devaaiStream,"stream") device(aao,INST_IO,devaaoStream,"stream") device(ai,INST_IO,devaiStream,"stream") device(ao,INST_IO,devaoStream,"stream") device(bi,INST_IO,devbiStream,"stream") device(bo,INST_IO,devboStream,"stream") device(calcout,INST_IO,devcalcoutStream,"stream") device(longin,INST_IO,devlonginStream,"stream") device(longout,INST_IO,devlongoutStream,"stream") device(mbbi,INST_IO,devmbbiStream,"stream") device(mbbiDirect,INST_IO,devmbbiDirectStream,"stream") device(mbbo,INST_IO,devmbboStream,"stream") device(mbboDirect,INST_IO,devmbboDirectStream,"stream") device(stringin,INST_IO,devstringinStream,"stream") device(stringout,INST_IO,devstringoutStream,"stream") device(waveform,INST_IO,devwaveformStream,"stream") device(scalcout,INST_IO,devscalcoutStream,"stream") driver(stream) registrar(streamRegistrar) variable(streamDebug,int)
________________________________ From: Peter Blanco [[email protected]] Sent: Wednesday, June 22, 2016 8:17 AM To: Mark Rivers; [email protected] Subject: Re: streams drivers
# RELEASE - Location of external support modules # # IF YOU MAKE ANY CHANGES to this file you must subsequently # do a "gnumake rebuild" in this application's top level # directory. # # The build process does not check dependencies against files # that are outside this application, thus you should do a # "gnumake rebuild" in the top level directory after EPICS_BASE # or any other external module pointed to below is rebuilt. # # Host- or target-specific settings can be given in files named # RELEASE.$(EPICS_HOST_ARCH).Common # RELEASE.Common.$(T_A) # RELEASE.$(EPICS_HOST_ARCH).$(T_A) # # This file should ONLY define paths to other support modules, # or include statements that pull in similar RELEASE files. # Build settings that are NOT module paths should appear in a # CONFIG_SITE file.
TEMPLATE_TOP=$(EPICS_BASE)/templates/makeBaseApp/top
ASYN=/home/blanco/Desktop/EPICS/support/asyn
# If using the sequencer, point SNCSEQ at its top directory: SNCSEQ=/home/blanco/Desktop/EPICS/support/seq
# EPICS_BASE usually appears last so other apps can override stuff: EPICS_BASE=/home/blanco/Desktop/EPICS/base
# Set RULES here if you want to take build rules from somewhere # other than EPICS_BASE: #RULES=/path/to/epics/support/module/rules/x-y
From: Mark Rivers <[email protected]> To: Peter Blanco <[email protected]>, "[email protected]" <[email protected]> Sent: 6/22/2016 9:11 AM Subject: RE: streams drivers
It sounds to me like there is a problem with your StreamDevice/configure/RELEASE file for StreamDevice. Can you please send the contents of that file?
________________________________ From: [email protected] [[email protected]] on behalf of Peter Blanco [[email protected]] Sent: Wednesday, June 22, 2016 7:49 AM To: [email protected] Subject: streams drivers
Hello,
I'm trying to use the “Glassman” Power Supply driver which uses streams, also tried a couple other streams drivers & also went through the tutorial steps to build one from scratch, all have same problem.
Below is a screen printout that I got when running the "Glassman" driver TestApp .
I believe the problem may be with the StreamDevice itself. The only place I could build StreamDevice without getting errors was EPICS/base, otherwise it would complain about not finding stuff. ASYN is defined in my release file for StreamDevice, but is not listed by dbior, as you can see from the printout. Instead AsynDriver is listed separately,. Is that normal ?
The call to drvAsynIPPortConfigure("L0", "192.168.1.93:5025", 0, 0, 0, 0) works fine, as it puts my device into Remote, but that's it.
The main errors I get for example are: Cannot find a bus named 'L0' for 'glassmanTest:1:CurrentSetpoint , glassmanTest:1:CurrentSetpoint: Can't attach to bus L0
I also typed 'help'so you can see the cmnds available, asyn stuff is there. Do you see anything that should be there that isn't ? also, dbl does give me the list of PVs, (not shown)
Does anyone know what may be wrong ? Would greatly appreciate your help.
Thanks, P.Blanco
blanco@kepcoubuntu-Precision-WorkStation-490:~/Desktop/EPICS/DEBUG/Glassman/iocBoot/iocGlassman$ '/home/blanco/Desktop/EPICS/DEBUG/Glassman/iocBoot/iocGlassman/Glassman' st.cmd #!../../bin/darwin-x86/Glassman ############################################################################ # Set up environment epicsEnvSet("P", "glassmanTest:") epicsEnvSet("R", "1:") epicsEnvSet("GLASSMAN_IP", "192.168.1.93:5025") < envPaths epicsEnvSet("ARCH","linux-x86_64") epicsEnvSet("IOC","iocGlassman") epicsEnvSet("TOP","/home/blanco/Desktop/EPICS/DEBUG/Glassman") epicsEnvSet("STREAM","/home/blanco/Desktop/EPICS/base/StreamDevice") epicsEnvSet("ASYN","/home/blanco/Desktop/EPICS/support/asyn") epicsEnvSet("EPICS_BASE","/home/blanco/Desktop/EPICS/base") epicsEnvSet("STREAM_PROTOCOL_PATH", "../../db") ############################################################################ # Register support components dbLoadDatabase "../../dbd/Glassman.dbd" Glassman_registerRecordDeviceDriver pdbbase ############################################################################ # Configure hardware drvAsynIPPortConfigure("L0", "192.168.1.93:5025", 0, 0, 0, 0) #asynSetOption("L0", -1, "baud", "9600") #asynSetOption("L0", -1, "bits", "8") #asynSetOption("L0", -1, "parity", "none") #asynSetOption("L0", -1, "stop", "1") #asynSetOption("L0", -1, "clocal", "Y") #asynSetOption("L0", -1, "crtscts", "N") #asynSetTraceIOMask("L0",-1,0x2) #asynSetTraceMask("L0",-1,0x09) ############################################################################ # Load record instances dbLoadRecords("../../db/devGlassman.db","P=glassmanTest:,R=1:,PORT=L0,Vmax=1000,Imax=300") dbLoadRecords("../../db/asynRecord.db","P=iocGlassman:,R=asyn,PORT=L0,ADDR=0,OMAX=100,IMAX=100") ############################################################################ # Start EPICS # cd "${TOP}/iocBoot/${IOC}" iocInit Starting iocInit ############################################################################ ## EPICS R3.14.12.5 $Date: Tue 2015-03-24 09:57:35 -0500$ ## EPICS Base built Jun 21 2016 ############################################################################ 2016/06/21 10:39:25.764800 _main_ Cannot find a bus named 'L0' for 'glassmanTest:1:CurrentSetpoint' 2016/06/21 10:39:25.764890 _main_ glassmanTest:1:CurrentSetpoint: Can't attach to bus L0 0 2016/06/21 10:39:25.764902 _main_ glassmanTest:1:CurrentSetpoint: Record initialization failed 2016/06/21 10:39:25.764926 _main_ Cannot find a bus named 'L0' for 'glassmanTest:1:VoltageSetpoint' 2016/06/21 10:39:25.764940 _main_ glassmanTest:1:VoltageSetpoint: Can't attach to bus L0 0 2016/06/21 10:39:25.764955 _main_ glassmanTest:1:VoltageSetpoint: Record initialization failed 2016/06/21 10:39:25.764978 _main_ Cannot find a bus named 'L0' for 'glassmanTest:1:Version' 2016/06/21 10:39:25.764995 _main_ glassmanTest:1:Version: Can't attach to bus L0 0 2016/06/21 10:39:25.765009 _main_ glassmanTest:1:Version: Record initialization failed 2016/06/21 10:39:25.765032 _main_ Cannot find a bus named 'L0' for 'glassmanTest:1:StMon_' 2016/06/21 10:39:25.765048 _main_ glassmanTest:1:StMon_: Can't attach to bus L0 0 2016/06/21 10:39:25.765062 _main_ glassmanTest:1:StMon_: Record initialization failed 2016/06/21 10:39:25.765082 _main_ Cannot find a bus named 'L0' for 'glassmanTest:1:OnOff' 2016/06/21 10:39:25.765097 _main_ glassmanTest:1:OnOff: Can't attach to bus L0 0 2016/06/21 10:39:25.765112 _main_ glassmanTest:1:OnOff: Record initialization failed 2016/06/21 10:39:26.267138 _main_ glassmanTest:1:Version: Record not initialised correctly iocRun: All initialization complete epicsThreadSleep(2) 2016/06/21 10:39:26.766826 scan1 glassmanTest:1:StMon_: Record not initialised correctly 2016/06/21 10:39:27.766823 scan1 glassmanTest:1:StMon_: Record not initialised correctly iocPause iocPause: IOC suspended epics> help Type 'help <command>' to see the arguments of <command>. # ClockTime_Report Glassman_registerRecordDeviceDriver asDumpHash asInit asSetFilename asSetSubstitutions ascar asdbdump asphag aspmem asprules aspuag astac asynAutoConnect asynEnable asynInterposeEosConfig asynInterposeFlushConfig asynOctetConnect asynOctetDisconnect asynOctetFlush asynOctetGetInputEos asynOctetGetOutputEos asynOctetRead asynOctetSetInputEos asynOctetSetOutputEos asynOctetWrite asynOctetWriteRead asynRegisterTimeStampSource asynReport asynSetAutoConnectTimeout asynSetMinTimerPeriod asynSetOption asynSetTraceFile asynSetTraceIOMask asynSetTraceIOTruncateSize asynSetTraceInfoMask asynSetTraceMask asynShowOption asynUnregisterTimeStampSource asynWaitConnect callbackSetQueueSize casr cd coreRelease date dbDumpBreaktable dbDumpDevice dbDumpDriver dbDumpField dbDumpFunction dbDumpMenu dbDumpPath dbDumpRecord dbDumpRecordType dbDumpRegistrar dbDumpVariable dbLoadDatabase dbLoadRecords dbLoadTemplate dbLockShowLocked dbNotifyDump dbPvdDump dbPvdTableSize dbReportDeviceConfig dba dbap dbb dbc dbcar dbd dbel dbgf dbgrep dbhcr dbior dbl dbla dblsr dbnr dbp dbpf dbpr dbs dbstat dbtgf dbtpf dbtpn dbtr drvAsynIPPortConfigure drvAsynIPServerPortConfigure drvAsynSerialPortConfigure eltc epicsEnvSet epicsEnvShow epicsMutexShowAll epicsParamShow epicsPrtEnvParams epicsThreadResume epicsThreadShow epicsThreadShowAll epicsThreadSleep errlog errlogInit errlogInit2 exit generalTimeReport gft help installLastResortEventProvider iocBuild iocInit iocLogInit iocLogShow iocPause iocRun iocshCmd pft pwd registryDeviceSupportFind registryDriverSupportFind registryDump registryFunctionFind registryRecordTypeFind scanOnceSetQueueSize scanpel scanpiol scanppl setIocLogDisable streamReload taskwdShow tpn var epics> dbior Driver: stream StreamDevice 2.7.6 built Jun 21 2016 10:23:43 registered bus interfaces: DebugInterface DummyInterface Driver: drvAsyn L0 multiDevice:No canBlock:Yes autoConnect:Yes epics>
- RE: streams drivers Mark Rivers
<2016>
<2016>
