OK, so your problem is starting with this line in your build output:
perl ../makeref.pl Interface Debug Dummy > streamReferences
This is what I get when I build 2.6
perl ../makeref.pl Interface Debug Dummy AsynDriver > streamReferences
It is also not compiling AsynDriverInterface.cc.
This really seems like it is a problem with the definition of ASYN in configure/RELEASE. Are you sure that there is no typo there?
Sent: Wednesday, June 22, 2016 11:34 AM
To: Mark Rivers; [email protected]
Subject: Re: streams drivers
I rebuilt 2.6, same problem. attaced is the output
Peter Blanco Test/Software Eng. Kepco Inc.
To: Peter Blanco <[email protected]>, "[email protected]" <[email protected]>
Sent: 6/22/2016 11:54 AM
Subject: RE: streams drivers
Yes, dbior is getting reports both from StreamDevice and from asynManager. That is normal. But the problem is that StreamDevice is not listing the asyn bus interface.
Can you send the complete output when you rebuild StreamDevice 2.7.6?
Sent: Wednesday, June 22, 2016 10:46 AM
I agree.
Actually I get 2 drivers listed separately :
epics> dbior
Driver: stream
StreamDevice 2.7.6 built Jun 21 2016 10:23:43
registered bus interfaces:
DebugInterface
DummyInterface
Driver: drvAsyn
L0 multiDevice:No canBlock:Yes autoConnect:Yes
epics>
According to the doc:
# asynDriver interface is added automatically
# if ASYN is defined in your RELEASE file.
I will try to use the 2.6 version, though I may have already done that.
Might it also be an issue with Ubuntu ?
Sent: 6/22/2016 10:01 AM
Your problem can be seen in the output of the dbior command. This is what I get
Driver: stream
StreamDevice 2.6.0 built May 11 2016 15:20:49
DebugInterface
DummyInterface
AsynDriverInterface
This is what you get:
Driver: stream
DebugInterface
DummyInterface
Note that you are missing AsynDriverInterface. That is the problem. Now the question is why?
I see you are using a more recent version of StreamDevice than I am. Perhaps there is something you need to set when you build StreamDevice now to enable the asyn bus interface?
Sent: Wednesday, June 22, 2016 8:37 AM
here it is :
blanco@kepcoubuntu-Precision-WorkStation-490:~/Desktop/EPICS/DEBUG/Glassman$ grep -i stream dbd/Glassman.dbd
device(aai,INST_IO,devaaiStream,"stream")
device(aao,INST_IO,devaaoStream,"stream")
device(ai,INST_IO,devaiStream,"stream")
device(ao,INST_IO,devaoStream,"stream")
device(bi,INST_IO,devbiStream,"stream")
device(bo,INST_IO,devboStream,"stream")
device(calcout,INST_IO,devcalcoutStream,"stream")
device(longin,INST_IO,devlonginStream,"stream")
device(longout,INST_IO,devlongoutStream,"stream")
device(mbbi,INST_IO,devmbbiStream,"stream")
device(mbbiDirect,INST_IO,devmbbiDirectStream,"stream")
device(mbbo,INST_IO,devmbboStream,"stream")
device(mbboDirect,INST_IO,devmbboDirectStream,"stream")
device(stringin,INST_IO,devstringinStream,"stream")
device(stringout,INST_IO,devstringoutStream,"stream")
device(waveform,INST_IO,devwaveformStream,"stream")
driver(stream)
registrar(streamRegistrar)
variable(streamDebug,int)
Sent: 6/22/2016 9:24 AM
That looks OK. Perhaps the problem is your application dbd file.
Send the output of
I get the following for my application:
corvette:~/devel/CARS/dbd>grep -i stream CARSLinux.dbd
device(scalcout,INST_IO,devscalcoutStream,"stream")
driver(stream)
Sent: Wednesday, June 22, 2016 8:17 AM
# RELEASE - Location of external support modules
# IF YOU MAKE ANY CHANGES to this file you must subsequently
# do a "gnumake rebuild" in this application's top level
# directory.
# The build process does not check dependencies against files
# that are outside this application, thus you should do a
# "gnumake rebuild" in the top level directory after EPICS_BASE
# or any other external module pointed to below is rebuilt.
# Host- or target-specific settings can be given in files named
# RELEASE.$(EPICS_HOST_ARCH).Common
# RELEASE.Common.$(T_A)
# RELEASE.$(EPICS_HOST_ARCH).$(T_A)
# This file should ONLY define paths to other support modules,
# or include statements that pull in similar RELEASE files.
# Build settings that are NOT module paths should appear in a
# CONFIG_SITE file.
TEMPLATE_TOP=$(EPICS_BASE)/templates/makeBaseApp/top
ASYN=/home/blanco/Desktop/EPICS/support/asyn
# If using the sequencer, point SNCSEQ at its top directory:
SNCSEQ=/home/blanco/Desktop/EPICS/support/seq
# EPICS_BASE usually appears last so other apps can override stuff:
EPICS_BASE=/home/blanco/Desktop/EPICS/base
# Set RULES here if you want to take build rules from somewhere
# other than EPICS_BASE:
#RULES=/path/to/epics/support/module/rules/x-y
Sent: 6/22/2016 9:11 AM
It sounds to me like there is a problem with your StreamDevice/configure/RELEASE file for StreamDevice. Can you please send the contents of that file?
From: [email protected] [[email protected]] on behalf of Peter Blanco [[email protected]]
Sent: Wednesday, June 22, 2016 7:49 AM
To: [email protected]
Subject: streams drivers
Hello,
I'm trying to use the “Glassman” Power Supply driver which uses streams, also tried a couple other streams drivers & also went through the tutorial steps to build one from scratch, all have same problem.
Below is a screen printout that I got when running the "Glassman" driver TestApp .
I believe the problem may be with the StreamDevice itself.
The only place I could build StreamDevice without getting errors was EPICS/base, otherwise it would complain about not finding stuff.
ASYN is defined in my release file for StreamDevice, but is not listed by dbior, as you can see from the printout. Instead AsynDriver is listed separately,. Is that normal ?
The call to drvAsynIPPortConfigure("L0", "192.168.1.93:5025", 0, 0, 0, 0) works fine, as it puts my device into Remote, but that's it.
The main errors I get for example are:
Cannot find a bus named 'L0' for 'glassmanTest:1:CurrentSetpoint ,
glassmanTest:1:CurrentSetpoint: Can't attach to bus L0
I also typed 'help'so you can see the cmnds available, asyn stuff is there. Do you see anything that should be there that isn't ?
also, dbl does give me the list of PVs, (not shown)
Does anyone know what may be wrong ? Would greatly appreciate your help.
Thanks, P.Blanco
blanco@kepcoubuntu-Precision-WorkStation-490:~/Desktop/EPICS/DEBUG/Glassman/iocBoot/iocGlassman$ '/home/blanco/Desktop/EPICS/DEBUG/Glassman/iocBoot/iocGlassman/Glassman' st.cmd
#!../../bin/darwin-x86/Glassman
# Set up environment
epicsEnvSet("P", "glassmanTest:")
epicsEnvSet("R", "1:")
epicsEnvSet("GLASSMAN_IP", "192.168.1.93:5025")
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","iocGlassman")
epicsEnvSet("TOP","/home/blanco/Desktop/EPICS/DEBUG/Glassman")
epicsEnvSet("STREAM","/home/blanco/Desktop/EPICS/base/StreamDevice")
epicsEnvSet("ASYN","/home/blanco/Desktop/EPICS/support/asyn")
epicsEnvSet("EPICS_BASE","/home/blanco/Desktop/EPICS/base")
epicsEnvSet("STREAM_PROTOCOL_PATH", "../../db")
# Register support components
dbLoadDatabase "../../dbd/Glassman.dbd"
Glassman_registerRecordDeviceDriver pdbbase
# Configure hardware
#asynSetOption("L0", -1, "baud", "9600")
#asynSetOption("L0", -1, "bits", "8")
#asynSetOption("L0", -1, "parity", "none")
#asynSetOption("L0", -1, "stop", "1")
#asynSetOption("L0", -1, "clocal", "Y")
#asynSetOption("L0", -1, "crtscts", "N")
#asynSetTraceIOMask("L0",-1,0x2)
#asynSetTraceMask("L0",-1,0x09)
# Load record instances
dbLoadRecords("../../db/devGlassman.db","P=glassmanTest:,R=1:,PORT=L0,Vmax=1000,Imax=300")
dbLoadRecords("../../db/asynRecord.db","P=iocGlassman:,R=asyn,PORT=L0,ADDR=0,OMAX=100,IMAX=100")
# Start EPICS
# cd "${TOP}/iocBoot/${IOC}"
iocInit
Starting iocInit
## EPICS R3.14.12.5 $Date: Tue 2015-03-24 09:57:35 -0500$
## EPICS Base built Jun 21 2016
2016/06/21 10:39:25.764800 _main_ Cannot find a bus named 'L0' for 'glassmanTest:1:CurrentSetpoint'
2016/06/21 10:39:25.764890 _main_ glassmanTest:1:CurrentSetpoint: Can't attach to bus L0 0
2016/06/21 10:39:25.764902 _main_ glassmanTest:1:CurrentSetpoint: Record initialization failed
2016/06/21 10:39:25.764926 _main_ Cannot find a bus named 'L0' for 'glassmanTest:1:VoltageSetpoint'
2016/06/21 10:39:25.764940 _main_ glassmanTest:1:VoltageSetpoint: Can't attach to bus L0 0
2016/06/21 10:39:25.764955 _main_ glassmanTest:1:VoltageSetpoint: Record initialization failed
2016/06/21 10:39:25.764978 _main_ Cannot find a bus named 'L0' for 'glassmanTest:1:Version'
2016/06/21 10:39:25.764995 _main_ glassmanTest:1:Version: Can't attach to bus L0 0
2016/06/21 10:39:25.765009 _main_ glassmanTest:1:Version: Record initialization failed
2016/06/21 10:39:25.765032 _main_ Cannot find a bus named 'L0' for 'glassmanTest:1:StMon_'
2016/06/21 10:39:25.765048 _main_ glassmanTest:1:StMon_: Can't attach to bus L0 0
2016/06/21 10:39:25.765062 _main_ glassmanTest:1:StMon_: Record initialization failed
2016/06/21 10:39:25.765082 _main_ Cannot find a bus named 'L0' for 'glassmanTest:1:OnOff'
2016/06/21 10:39:25.765097 _main_ glassmanTest:1:OnOff: Can't attach to bus L0 0
2016/06/21 10:39:25.765112 _main_ glassmanTest:1:OnOff: Record initialization failed
2016/06/21 10:39:26.267138 _main_ glassmanTest:1:Version: Record not initialised correctly
epicsThreadSleep(2)
2016/06/21 10:39:26.766826 scan1 glassmanTest:1:StMon_: Record not initialised correctly
2016/06/21 10:39:27.766823 scan1 glassmanTest:1:StMon_: Record not initialised correctly
iocPause
iocPause: IOC suspended
epics> help
Type 'help <command>' to see the arguments of <command>.
# ClockTime_Report
Glassman_registerRecordDeviceDriver asDumpHash asInit
asSetFilename asSetSubstitutions ascar asdbdump
asphag aspmem asprules aspuag astac
asynAutoConnect asynEnable asynInterposeEosConfig
asynInterposeFlushConfig asynOctetConnect
asynOctetDisconnect asynOctetFlush asynOctetGetInputEos
asynOctetGetOutputEos asynOctetRead asynOctetSetInputEos
asynOctetSetOutputEos asynOctetWrite asynOctetWriteRead
asynRegisterTimeStampSource asynReport asynSetAutoConnectTimeout
asynSetMinTimerPeriod asynSetOption asynSetTraceFile
asynSetTraceIOMask asynSetTraceIOTruncateSize
asynSetTraceInfoMask asynSetTraceMask asynShowOption
asynUnregisterTimeStampSource asynWaitConnect callbackSetQueueSize
casr cd coreRelease date
dbDumpBreaktable dbDumpDevice dbDumpDriver dbDumpField
dbDumpFunction dbDumpMenu dbDumpPath dbDumpRecord
dbDumpRecordType dbDumpRegistrar dbDumpVariable dbLoadDatabase
dbLoadRecords dbLoadTemplate dbLockShowLocked dbNotifyDump
dbPvdDump dbPvdTableSize dbReportDeviceConfig dba
dbap dbb dbc dbcar dbd
dbel dbgf dbgrep dbhcr dbior
dbl dbla dblsr dbnr dbp
dbpf dbpr dbs dbstat dbtgf
dbtpf dbtpn dbtr drvAsynIPPortConfigure
drvAsynIPServerPortConfigure drvAsynSerialPortConfigure eltc
epicsEnvSet epicsEnvShow epicsMutexShowAll epicsParamShow
epicsPrtEnvParams epicsThreadResume
epicsThreadShow epicsThreadShowAll epicsThreadSleep
errlog errlogInit errlogInit2 exit
generalTimeReport gft help
installLastResortEventProvider iocBuild iocInit iocLogInit
iocLogShow iocPause iocRun iocshCmd pft
pwd registryDeviceSupportFind registryDriverSupportFind
registryDump registryFunctionFind registryRecordTypeFind
scanOnceSetQueueSize scanpel scanpiol scanppl
setIocLogDisable streamReload taskwdShow tpn
var
epics> dbior
Driver: stream
DebugInterface
DummyInterface
Driver: drvAsyn
epics>
- RE: streams drivers Mark Rivers
- Re: streams drivers Peter Blanco
<2016>
<2016>
