>> I also changed the “appliance.xml” file to match the quickstart demo version
The quickstart.sh and single_machine_install.sh are fundamentally two different deployment models. The "quickstart.sh" runs all
the WAR files in a single Tomcat instance; thus all the ports in your appliance.xml will be 17665.
The "single_machine_install.sh" uses four separate tomcat instances; one each for each of the components. Your
"sampleStartup.sh" will start up four different tomcat's; each of which listen on different ports. This is
probably the
reason why you are getting this exception
java.io.IOException: Invalid status calling http://localhost:17665/engine/bpl/getVersion. Got 404Not Found
I would first try to reuse you original appliances.xml. Make sure the four component start up correctly without exceptions first.
If you need more help, ping feel free to ping me offline.
Murali
