1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Linking agains .so library on linux
To: "Rivers, Mark L." <[email protected]>
Date: Mon, 20 Jun 2016 18:07:26 +0000
Thanks (again) Mark.
I got it to work as long as I copied the libs to my ADPCO/lib/linux_x86_64 dir.
To point the linker to the right dir I am using:
PROD_LDFLAGS +=-Wl,-rpath,/local/pco/sisw/lib64
That path does show up in the final link command, but it cannot find the libs in that dir. How does one tell a directory with PROD_SYS_LIBS?
Make file is like this:
PROD_LIBS += pco
PROD_LIBS += cameralink caputRecorder
PROD_SYS_LIBS += clsersis display fglib5
The command is like  below. The only snag at this point is that I don't know how to point the linker to the proper dir containing the PROD_SYS_LIBs.
Thanks again
T
/usr/bin/g++ -o pcoApp -Wl,-Bstatic -L/local/pco/EPICS/base-3.14.12.5/lib/linux-x86_64 -L/local/pco/EPICS/synApps_5_5/support/areaDetector/ADCameralink/lib/linux-x86_64 -L/local/pco/EPICS/synApps_5_5/support/areaDetector/ADCore/lib/linux-x86_64 -L/local/pco/EPICS/synApps_5_5/support/areaDetector/ADPCO/lib/linux-x86_64 -L/local/pco/EPICS/synApps_5_5/support/asyn4-26/lib/linux-x86_64 -L/local/pco/EPICS/synApps_5_5/support/autosave-4-7/lib/linux-x86_64 -L/local/pco/EPICS/synApps_5_5/support/busy-1-3/lib/linux-x86_64 -L/local/pco/EPICS/synApps_5_5/support/calc-2-8/lib/linux-x86_64 -L/local/pco/EPICS/synApps_5_5/support/caputRecorder-1-4-2/lib/linux-x86_64 -L/local/pco/EPICS/synApps_5_5/support/seq-2-2-3/lib/linux-x86_64 -L/local/pco/EPICS/synApps_5_5/support/sscan-2-6-6/lib/linux-x86_64 -L/local/pco/hdf/lib -L/local/pco/szip/lib -Wl,-rpath,/local/pco/EPICS/base-3.14.12.5/lib/linux-x86_64 -Wl,-rpath,/local/pco/EPICS/synApps_5_5/support/areaDetector/ADCameralink/lib/linux-x86_64 -!
 Wl,-rpath,/local/pco/EPICS/synApps_5_5/support/areaDetector/ADCore/lib/linux-x86_64 -Wl,-rpath,/local/pco/EPICS/synApps_5_5/support/areaDetector/ADPCO/lib/linux-x86_64 -Wl,-rpath,/local/pco/EPICS/synApps_5_5/support/asyn4-26/lib/linux-x86_64 -Wl,-rpath,/local/pco/EPICS/synApps_5_5/support/autosave-4-7/lib/linux-x86_64 -Wl,-rpath,/local/pco/EPICS/synApps_5_5/support/busy-1-3/lib/linux-x86_64 -Wl,-rpath,/local/pco/EPICS/synApps_5_5/support/calc-2-8/lib/linux-x86_64 -Wl,-rpath,/local/pco/EPICS/synApps_5_5/support/caputRecorder-1-4-2/lib/linux-x86_64 -Wl,-rpath,/local/pco/EPICS/synApps_5_5/support/seq-2-2-3/lib/linux-x86_64 -Wl,-rpath,/local/pco/EPICS/synApps_5_5/support/sscan-2-6-6/lib/linux-x86_64 -Wl,-rpath,/local/pco/hdf/lib -Wl,-rpath,/local/pco/szip/lib        -m64        -Wl,-rpath,/local/pco/sisw/lib64        pcoApp_registerRecordDeviceDriver.o pcoAppMain.o   -lpco -lcameralink -lcaputRecorder -lNDPlugin -lADBase -lnetCDF -lNeXus -lcalc -lbusy -lsscan -lautosave -lasyn !
 -lseq -lpv -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtools!
 Ioc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lhdf5 -lsz -Wl,-Bdynamic -lclsersis -ldisplay -lfglib5 -ltiff -ljpeg -lxml2 -lz -lpthread   -lreadline -lm -lrt -ldl -lgcc
_____________________________
Sent: Monday, June 20, 2016 12:18 PM
To: Madden, Timothy J.
Cc: [email protected]
Subject: Re: Linking agains .so library on linux
You need to reference your vendor .so file using PROD_SYS_LIBS not PROD_LIBS.
Sent from my iPhone
On Jun 20, 2016, at 11:15 AM, Madden, Timothy J. <[email protected]<mailto:[email protected]>> wrote:
Dear EPICS:
I want to link an IOC against an .so supplied by a vendor. The compile seems to only look for .a type libraries.
Also I notice that on linking, -Bstatic is turned on. (I am using linux).
I have epics base CONFIG_SITE file set to:
SHARED_LIBRARIES=YES
#  Build client objects statically ?
#        must be either YES or NO
STATIC_BUILD=NO
This seems like it should work.
How do I get rid of the -Bstatuc on my link, so it will look for .so files on link?
Here is the failing command:
/usr/bin/g++ -o pcoApp -Wl,-Bstatic -L/local/pco/EPICS/base-3.14.12.5/lib/linux-x86_64 -L/local/pco/EPICS/synApps_5_5/support/areaDetector/ADCameralink/lib/linux-x86_64 -L/local/pco/EPICS/synApps_5_5/support/areaDetector/ADCore/lib/linux-x86_64 -L/local/pco/EPICS/synApps_5_5/support/areaDetector/ADPCO/lib/linux-x86_64 -L/local/pco/EPICS/synApps_5_5/support/asyn4-26/lib/linux-x86_64 -L/local/pco/EPICS/synApps_5_5/support/autosave-4-7/lib/linux-x86_64 -L/local/pco/EPICS/synApps_5_5/support/busy-1-3/lib/linux-x86_64 -L/local/pco/EPICS/synApps_5_5/support/calc-2-8/lib/linux-x86_64 -L/local/pco/EPICS/synApps_5_5/support/caputRecorder-1-4-2/lib/linux-x86_64 -L/local/pco/EPICS/synApps_5_5/support/seq-2-2-3/lib/linux-x86_64 -L/local/pco/EPICS/synApps_5_5/support/sscan-2-6-6/lib/linux-x86_64 -L/local/pco/hdf/lib -L/local/pco/sisw/lib64 -L/local/pco/szip/lib -Wl,-rpath,/local/pco/EPICS/base-3.14.12.5/lib/linux-x86_64 -Wl,-rpath,/local/pco/EPICS/synApps_5_5/support/areaDetector/ADCamer!
 alink/lib/linux-x86_64 -Wl,-rpath,/local/pco/EPICS/synApps_5_5/support/areaDetector/ADCore/lib/linux-x86_64 -Wl,-rpath,/local/pco/EPICS/synApps_5_5/support/areaDetector/ADPCO/lib/linux-x86_64 -Wl,-rpath,/local/pco/EPICS/synApps_5_5/support/asyn4-26/lib/linux-x86_64 -Wl,-rpath,/local/pco/EPICS/synApps_5_5/support/autosave-4-7/lib/linux-x86_64 -Wl,-rpath,/local/pco/EPICS/synApps_5_5/support/busy-1-3/lib/linux-x86_64 -Wl,-rpath,/local/pco/EPICS/synApps_5_5/support/calc-2-8/lib/linux-x86_64 -Wl,-rpath,/local/pco/EPICS/synApps_5_5/support/caputRecorder-1-4-2/lib/linux-x86_64 -Wl,-rpath,/local/pco/EPICS/synApps_5_5/support/seq-2-2-3/lib/linux-x86_64 -Wl,-rpath,/local/pco/EPICS/synApps_5_5/support/sscan-2-6-6/lib/linux-x86_64 -Wl,-rpath,/local/pco/hdf/lib -Wl,-rpath,/local/pco/sisw/lib64 -Wl,-rpath,/local/pco/szip/lib        -m64                pcoApp_registerRecordDeviceDriver.o pcoAppMain.o   -lpco -lcameralink -lcaputRecorder -lclsersis -lNDPlugin -lADBase -lnetCDF -lNeXus -lca!
 lc -lbusy -lsscan -lautosave -lasyn -lseq -lpv -lrecIoc -lsoft!
 DevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lhdf5 -lsz -Wl,-Bdynamic -ltiff -ljpeg -lxml2 -lz -lpthread   -lreadline -lm -lrt -ldl -lgcc
/usr/bin/ld: cannot find -lclsersis
collect2: ld returned 1 exit status
Tim Madden
Argonne
Re: Linking agains .so library on linux Andrew Johnson
Linking agains .so library on linux Madden, Timothy J.
Re: Linking agains .so library on linux Mark Rivers
Prev: Re: Linking agains .so library on linux Andrew Johnson
Next: Re: Linking agains .so library on linux Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Linking agains .so library on linux Mark Rivers
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
