1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problem in base 3.15.x at runtime
To: [email protected]
Date: Thu, 16 Jun 2016 13:12:42 -0400
On 06/15/2016 05:24 AM, Shantonu Sahoo wrote:
> A call to 'assert(prt->no_fields == 308)'
This assertion checks the consistency of the .dbd information used at
compile time with what is loaded at runtime.  When I've hit this it was
because I accidentally loaded a .dbd from an older version of epics base.
Problem in base 3.15.x at runtime Shantonu Sahoo
Prev: Array record type in EPICS OPC device support Luca Cavalli
Next: MCA under windows7 64-bit Hinxx
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Problem in base 3.15.x at runtime Shantonu Sahoo
Next: Access TIME field of a PV Elmer Pensack
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
