1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Access TIME field of a PV
To: [email protected]
Date: Wed, 15 Jun 2016 18:03:54 -0400
You will need to run a soft IOC to generate timestamp PVs.
Here is a sample db record that will perform the desired task.
record(stringin, "${PV}:T") {
  field(DTYP, "Soft Timestamp")
  field(TSEL, "${PV}.TIME CP")
  field(INP, "@%b %d %Y %H:%M:%S")
Where ${PV} is the record you wish to monitor for update time.
Cheers,
Tim Southern
[email protected]
On 6/15/16 10:32 AM, Mark Rivers wrote:
There is device support in EPICS base for a stringin record to display the timestamp of a record.  Look at this tech-talk note:
http://www.aps.anl.gov/epics/tech-talk/2006/msg00017.php<http://www.aps.anl.gov/epics/tech-talk/2006/msg00017.php>
From: [email protected] [[email protected]] on behalf of Elmer Pensack [[email protected]]
Sent: Wednesday, June 15, 2016 9:06 AM
Subject: Access TIME field of a PV
Hello,
I have a MEDM display with several text message PVs. The users want to know when the PVs last updated because they don’t update frequently, I thought it would be easy - I’d just display the TIME field next to the message, only to find that TIME is not accessible. So is there an easy way to display the last update time? I was hoping not to need to write code to do it.
Thanks for any suggestions.
Elmer Pensack
Access TIME field of a PV Elmer Pensack
RE: Access TIME field of a PV Mark Rivers
Prev: Pending pull requests Henrique Almeida
Next: the problem about the driver package s7plc.tgz 许婕
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Access TIME field of a PV Arnold, Ned D.
Next: Pending pull requests Henrique Almeida
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
